Man kann sich freuen:
Comming next als public Version
DVD-RB 0.65
Zitat- Integrated an exciting new visual interface designed by Rockas. Thanks, my friend. May the road rise up to meet you, and the wind be always at your back. This interface is the first step in enabling "skin" capability for DVD-RB.
- Multiple angles and ILVU (Interleaved VOBU Units) are now supported.
The method used has worked successfully on all multiangle and seamless branching discs I've tested to date.- Note: The greatest challenge I've run into with multiple angles and ILVU is that they are already pretty tightly bitrate bound -- and any smaller sizing at all seems to noticably degrade the quality. So for this version I've decided to not further compress the ILVU portion of a film. In my testing it has shown to not be worth the quality loss -- the largest ILVU portion of any film I've found is too small to have any significant impact on available bitrate.
I can readdress if anyone finds a DVD in which this isn't the case.- Fixed an error in which the "Steal Space From Extras" settings were not loading properly from .RBD files during batch encoding.
- Added a new selection list to the main screen so subpicture streams can now be individually selected. Be careful when removing subpictures, especially when they are shown as "Unk" -- some special features can rely on subpictures. I personally never remove any subpictures -- they are too small to even consider for recovering space.
