ZitatAlles anzeigen
As a little christmas present to the xine community,
xine-lib 1.0 is finally released on christmas 2004.This release has been thoroughly tested during the past
2 years, with lots of pre-releases installed by thousands of
users all over the world.Compared with the latest release candidate, there are no big changes.
However, a security issue in the AIFF demuxer has been
addressed, as well as linking issues with the most popular
video output plugin (Xv) on some systems.
Therefore you are highly recommended to upgrade to this
officially bug-free releaseChanges:
xine-lib (1.0)
* unbreak DXR3 plugin
* fix crash in the AIFF demuxer on oversized chunks
* fix crash in the sputext decoder when subtitles have too many lines
[bug #1086775]
* added support for OGG chained streams
* fixed deadlock with ASF chained streams due to fifo buffer leak
* DVB Subtitles: fixed flashing, repeating subs, fix sync & timeouts
* DVB EPG: fixed incorrectly parsed running status, clear old epg data, cropped epg texts
* updated included libdvdnav: more graceful handling of some error conditions;
fixed playback of some strangely authored DVDs
* fixed problem with first subtitle not showing when using separate subtitle files
* fixed crash related to relative HTTP redirect URLs (implemented canonicalisation)
* linking libXv dynamically, fixes breakage of Xv plugin
https://sourceforge.net/project/showfiles.php?group_id=9655
Quelle: http://www.xinehq.de/
