ZitatTrotz des Verlustes einiger Entwickler
Es handelt sich nur um einen...
sysKin und Pengvado - welcher?
[font=verdana, arial, helvetica]Revision 206:
VFW build: http://www.aziendeassociate.com/x26..._rev206_mmx.exe
r206: [mp4] ftyp & moov boxes at the begining of the file, (thanks to jeanlf
for comments)
LigH: Beide
[/font]
ZitatsysKin und Pengvado - welcher?
Bisher nur sysKin. Pengvado ist nach wie vor die treibende Kraft von x264.
Bobololo von Ateme sendet ab und zu patches fuer x264, allerdings keine die mit dem Core zu tun haben.
[font=verdana, arial, helvetica]Revision 207:
VFW build: http://www.aziendeassociate.com/x26..._rev207_mmx.exe
Changelog:
r207: VfW: build from main makefile
[/font][font=verdana, arial, helvetica]______________________________________________________
Revision 209:
VFW build: http://www.aziendeassociate.com/x26..._rev209_mmx.exe
[/font][font=verdana, arial, helvetica]Changelog:
[/font][font=verdana, arial, helvetica]r208: CLI: progress indicator
r209: 10l (CLI: fflush after progress update)
[/font][font=verdana, arial, helvetica]______________________________________________________[/font]
[/font][font=verdana, arial, helvetica]Revision 211:
VFW build: http://www.aziendeassociate.com/x26..._rev211_mmx.exe
[/font][font=verdana, arial, helvetica]r210: misc makefile changes.
propogate --extra-cflags to vfw.
'make clean' removes x264.exe and vfw.
tweak dependencies.
r211: Allow manual selection of fullpel ME method. New method: Exhaustive search. based on a patch by Tuukka Toivonen.
[/font]
Neuer Link zum (jetzt Sticky-) Beitrag: http://forum.doom9.org/showthread.php?s=&threadid=89979
http://www.aziendeassociate.com/x264/X264VFW_rev214A_mmx.exe
http://www.aziendeassociate.com/x264/X264CLI_rev214A_mmx.rar
(r214A) Updated to the latest GPAC sources. Added bobololo's patch until it gets committed.
(r214) combined L0 & L1 reference lists are limited to a total of 16 pics.
(r213) amd64 asm patch, part2.
(r212) amd64 asm patch, part1.
Empfohlene ffdshow-Version (inkl. B-Pyramiden-Support): http://www.aziendeassociate.it/cd/ffdshow/ffdshow-20050406.exe
[font=verdana, arial, helvetica]Revision 215:
[/font][font=verdana, arial, helvetica]http://www.aziendeassociate.com/x26..._rev215_mmx.exe
http://www.aziendeassociate.com/x26..._rev215_mmx.rar
r215: CLI (mp4): return to 'capture' output mode, remove useless SetCtsPackMode() (fixed in gpac).
Note: requires gpac cvs-20050419 or later.
patch by bobo.
[/font][font=verdana, arial, helvetica]Revision 216:
http://www.aziendeassociate.com/x26..._rev216_mmx.exe
http://www.aziendeassociate.com/x26..._rev216_mmx.rar
r216: 10l (214 wrote wrong DPB size in SPS -> B-pyramid broke)[/font]
Rev 217
http://www.aziendeassociate.com/x264/X264VFW_rev217_mmx.exe VFW
http://www.aziendeassociate.com/x264/X264CLI_rev217_mmx.rar CLI
Changelog:
cosmetics. silence some gcc warnings. amd64 doesn't need a separate copy of the ...
[font=verdana, arial, helvetica]Revision 218:
VFW: http://www.aziendeassociate.com/x26..._rev218_mmx.exe
CLI: http://www.aziendeassociate.com/x26..._rev218_mmx.rar
[/font]Changelog:
r218: Updated MSVC project files.
[font=verdana, arial, helvetica]Revision 222:
http://www.webalice.it/f.corriga/x2..._rev222_mmx.exe
http://www.webalice.it/f.corriga/x2..._rev222_mmx.rar[/font]
Changelog:
r219: "2pass failed to converge" is no longer considered fatal.
r220: Cleaner allocation of tmp space in halfpel interpolation; fixes some valgrind/nasm warnings.
r221: slight speedup in halfpel interpolation.
r222: use a predicted mv as starting point for subpel refinement.
[font=verdana, arial, helvetica]Use this ffdshow version (built by Celtic Druid) for playing back x.264: http://www.aziendeassociate.it/cd/f...ow-20050406.exe[/font]
Revision 223:
"New ratecontrol options:
1pass ABR. VBV constraint for ABR and 2pass.
There is no longer a dedicated CBR mode: use ABR+VBV.
VfW now uses ABR instead of CQP for 1st of multipass."
Der lang angekündigte Patch für die 1pass Ratecontrol.
Revision 224:
Einige Optimierungen für die PowerPC Architektur (ca 17% Geschwindigkeitszuwachs)
hat sich was im vfw Frontend geändert ?
Noch hat Sharktooth keine Builds neuer als Rev. 222 im Angebot...
nach dem Skript Build von http://www.x264.nl hat sich vermutlich nichts am Frontend geändert (ich kann das nicht so genau sagen, war nicht auf dem neuesten Stand bis vorher)
[font=verdana, arial, helvetica]Revision 236
http://www.webalice.it/f.corriga/x2..._rev236_mmx.exe
- IMPORTANT - UNINSTALL ANY PREVIOUS BUILD BEFORE INSTALLING THIS ONE
http://www.webalice.it/f.corriga/x2...I_rev236_mmx.7z
Sources: http://www.webalice.it/f.corriga/x2...4_rev236_src.7z
[/font][font=verdana, arial, helvetica]http://www.webalice.it/f.corriga/x264/X264_rev235_src.7z[/font][font=verdana, arial, helvetica]
Changelog:
r225: port recent MC asm changes to amd64.
r226: fix an uninitialized value in slicetype_analyse
r227: CLI option: --visualize
Displays the encoded video along with MB types and motion vectors.
[/font][font=verdana, arial, helvetica]Updated to the latest GPAC sources and compiled GPAC with MMX and some other speed optimization cflags. x264 CLI could be a bit bigger than previous builds. VFW: Added uninstall icon to the start menu.
r228: CLI option: --seek
r229: ppc/*: more tuning on satd (+5%)
r230: visualize reference pic numbers. misc cleanups in visualization.
r231: ppc/: compile fixes for Linux/PPC (courtesy of Rasmus Rohde) and for gcc < 4
[/font][font=verdana, arial, helvetica] r232A: CLI: Updated to the latest GPAC sources and removed -funroll-loops from the GPAC cflags (no speed gain and bigger filesizes).
[/font][font=verdana, arial, helvetica] r233B: VFW: New x264 start menu icon.
[/font][font=verdana, arial, helvetica] r233C: Updated GPAC and misc stuff.
[/font][font=verdana, arial, helvetica] r234: VFW: Updated installer script and NSIS version. CLI&SRC: Moved from RAR to 7zip format. 7zip is free and can be downloaded here: http://www.7-zip.org/. Recent WinRAR versions can open and decompress 7zip archives too.
[/font][font=verdana, arial, helvetica] r234B: Updated to the latest GPAC sources.
r235: API: x264_encoder_reconfig(). (not yet used by any frontend)
r236: fix rounding of intra dequant when qp<=3
[/font] [font=verdana, arial, helvetica]
Keine Änderungen an der GUI!
[/font]
Revision 239
VfW codec: X264VFW_rev239_mmx.exe
CLI app: X264CLI_rev239_mmx.7z
Sources: X264_rev239_src.7z
r237: Zoned ratecontrol
r238: UMHex motion seach (but no early termination yet)
r239: move zones parsing to ratecontrol.c; allows passing in zones as a string.
Hurra - wir haben Zonen! :daumen: -- Jedoch wohl noch nicht in der VfW-GUI... :heul:
Laut devel ML wurde in revision 240 theating auf slice ebene eingeführt. Damit kann man jetzt auf multiprozessor System und hyperthreat systemen eine bessere Performence erwarten.
Nice
Warte ja nur darauf, dass Sharktooth etwas Zeit findet, dass Ganze in das vfw Frontend zu integrieren.
ZitatAlles anzeigenr242 | pengvado | 2005-05-30 03:52:00 +0200 (Mon, 30 May 2005) | 2 lines
tweak cflags
r241 | titer | 2005-05-29 22:27:09 +0200 (Sun, 29 May 2005) | 2 linesFixed multithreading on BeOS (pthread emulation required)
r240 | pengvado | 2005-05-29 20:28:49 +0200 (Sun, 29 May 2005) | 2 linesmultithreading (via slices)
Und da ist es auch schon:
Revision 242
Win32 VFW build: http://www.webalice.it/f.corriga/x2..._rev242_mmx.exe - (only MMX required - optimized for Pentium2 class CPUs and newer)
- WARNING - PRE REV.234 BUILDS MUST BE UNINSTALLED BEFORE INSTALLING THIS ONE
Win32 CLI singlethreaded build: http://www.webalice.it/f.corriga/x2...I_rev242_mmx.7z - (only MMX required - optimized for Pentium2 class CPUs and newer)
Win32 CLI multithreaded build: http://www.webalice.it/f.corriga/x2...I_rev242_thr.7z - (For HyperThreading/SMP/Dualcore systems)
Tools: http://www.webalice.it/f.corriga/x2...i_rev153_mmx.7z (only MMX required - optimized for Pentium2 class CPUs and newer)
Sources: http://www.webalice.it/f.corriga/x2...4_rev242_src.7z
=> "sito web non attivo"
Aber der r243er Download geht
r243 | mru | 2005-05-30 21:47:02 +0200 (Mon, 30 May 2005) | 2 linesaccept the standard --prefix etc. options
Jedoch keine Änderung im vfw Frontend.
