MeGUI Encoding-Frontend: aktuelle Versionen
  • 2098
  • Rev. 2101 mit FFMS 2.17
    2101 [M2TS muxer] added some missing audio types
    2100 [x264] check if files for --qpfile/--cqmfile are available
    improved --min-keyint default value calculation
    removed automatic deactivation of x64 x264 in case of an error
    2099 fixed a crash introduced in 2095 when using .NET 2.0 SP1 or older
  • 2103
    2103 [MediaInfo] fixed opening of DG index files if the source file is using not only 7bit ASCII characters
    2102 [MediaInfo] added StreamOrder to the MediaInfo wrapper (requires mediainfo revision 0.7.53+)
  • 2106
    2106 [File Indexer] fixed trying to extract audio from MKV files without audio when using the FFMS indexer
    2105 [Audio Encoder] show the opening of files in the job progress window as FFAudioSource may need some time to index files
    fixed crash when using DTS-ES with NicAudio
    2104 [MediaInfo] fixed "File not found" error in the wrapper. Bug #3480347
  • 2110
  • 2112
  • 2115
    2115 [HD Streams Extractor] fixed handling of english tracks in a MKV container when the track name contains a language
    2114 [MKV Muxer] adjusted (de)muxer to the recent mkvmerge changes (requires mkvmerge revision 5.3.0+)
    2113 [Job] translate process exit codes to status messages
  • 2122
    2122 [Progress Window] added job name. Feature request #3488205
    2121 [Audio Encoder] Import() will be used for AVS input files. Bug #3506283
    2120 [MKV Muxer] improved handling of empty IDX subtitle files
    2119 [MKV Muxer] added job status message during muxing
    2118 [MediaInfo] improved information detection for DVD sources
  • 2127
    2127 [AVS Script Creator] improved automatic cropping
    2126 [AVS Script Creator] crop values will only be added to the script if necessary
    2125 [Job] improved aborting of jobs part II
    2124 [Job] improved aborting of jobs
    2123 [Log] use system default encoding for AviSynth input script
  • 2129
    2129 [AutoEncode] enabled option to set the audio language
    2128 [Audio Encoder] NicAudio will be tried for DTS-MA decoding when DirectShowSource and FFAudioSource fail
  • 2138
  • Da steht uns wohl eine verbesserte Unterstützung kompletter DVDs bevor?
    In der Tat wird es solch eine Unterstützung geben. Allerdings wird es noch ein Weilchen dauern, bis diese auch in der nomalen MeGUI Version ankommen wird. Wer schon mal einen Blick in die Zukunft und damit auf die nächste OneClick Version werfen will:
    http://forum.doom9.org/showthread.php?t=163399
  • Rev. 2147
    Ich bekomme allerdings einen Loop, es wird immer zwischen Revision 2144 und 2147 hin und her geupdatet?!
    Nur kurzzeitig, bleibt jetzt bei 2147.
    Auf gute Zusammenarbeit:
    Einmal editiert, zuletzt von LigH (1. Mai 2012 um 15:17)
