2098
ZitatAlles anzeigen2098 [x264] added option to adjust GOP size based on the FPS of the source (enabled by default)
changed --weightp and --min-keyint default value calculation
2097 [Bitrate Calculator] improved M2TS calculation assumption. Warning: it is better but also not correct
2096 [Update] changed recommended path for neroaacenc to tools\eac3to
2095 [Log] changed resource lock behavior. Bug #3466426
2094 [MP4 Muxer] use ISO 639-2/T language codes when muxing. Bug #3201829
2093 [Update] if a component is missing a warning message will appear at startup
2092 [MainForm] offer to install AviSynth if AviSynth is not found but the installer is availabe (x86 only)
2091 [Settings] changed default value of "Autostart Queue" to enabled
2090 [Audio Encoder] do not abort downmix anymore if input avs file has no channel position information
2089 [HD Streams Extractor] defaulting to English if the track language can not be indentified (MKV only)
2088 [Audio Encoder] cosmetics
