hallo,
ich bin schon am verzweifeln. ich versuch ein mkv das nen h264 video und n ac3 audio enthält mit virtual dub mod zu öffnen. jedesmal kommt das:
[!] MKV: A frame of stream 1 (at 5047 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5172 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5255 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5380 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5464 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5547 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 5631 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 7883 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 12095 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 12262 ms) had only a forward reference (maybe
broken file).
[!] MKV: A frame of stream 1 (at 12971 ms) had only a forward reference (maybe
broken file).
... (geht ewig weiter so, tausende solche fehler)
[!] MKV: Video frames seems to be weirdly ordered.
[!] Couldn't locate decompressor for format 'ÿÿÿÿ' (unknown).
VirtualDub requires a Video for Windows (VFW) compatible codec to
decompress video. DirectShow codecs, such as those used by Windows Media
Player, are not suitable. Only 'Direct stream copy' is available for this
video.
Alles anzeigen
was ich halt nich kapier is warum der nicht das format erkennt (ffdshow is installed und h264 angemacht). ich hab schon das ding neu in nen mkv gepackt und auch den fourcc auf h264 geschrieben -> ändert nichts.
ja, was mach ich falsch??
kann ich das video irgendwie reparieren oder muss ich das neu encodieren??
mfg max
