Hi all
welche Filter muss ich loaden um iip zu nutzen finde keine Hinweis darauf danke
Wolli
iip05a
iiP v.0.5a
Benötigte Plugins:DustV5.dll -> http://home.arcor.de/dhanselmann/_stuff/dust_v5.zip
aWarpSharp.dll -> http://ziquash.chez-alice.fr/
Masktools.dll -> http://manao4.free.fr/MaskTools-v1.5.8.zip
warpsharp.dll, LoadPluginEx.dll -> http://www.geocities.co.jp/SiliconValley-PaloAlto/2382/
UnDot.dll -> http://www.trbarry.com/UnDot.zipSo steht es in der beiliegenden Textdatei
Was ist mit diesen 3 Links? :
http://forum.gleitz.info/showthread.php?t=26534
http://forum.doom9.org/showthread.php…7100#post517100
http://forum.gleitz.info/showpost.php?p=254389&postcount=16Edit: da war -doc- schneller.
# PLUGINS laden
LoadPlugin("C:\Programme\AviSynth\plugins\DGDecode.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\DeBlock.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\DustV5.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\awarpsharp.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\MaskTools.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\Undot.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\warpsharp.dll")
Import("C:\GK\Delogo.avs")
Import("C:\GK\iip.avs")mpeg2source("C:\GK\StarWarsEpisodeIIAngriffderKlonkrieger.d2v")
Deblock(30)crop( 8, 120, -8, -120)
#Crop( width-120, 0, 120, 60 )
#SelectRangeEvery( 56, 1 )
#TemporalSoften( 3,255,255,255,2 )DeLogo( 120,60, "RO", "1", Cmix=0.0, Lmix=0.0)
iip( dest_x= XXX, dest_y= YYY,
\ ss1_x = 1.414, ss1_y = 1.414,
\ duststr = 2, dustweight = 1.0, antiflicker1= true, antiflicker2= true,
\ detailcontr1= 104, detailcontr2 = 208, contr_radius = 2, PixSharp=0.38,
\ ss2_x = 3.5, ss2_y = 3.5,
\ Xstren = 255, Xlimit = 255,
\ subpelstren= 1.58, flatweight = 0,
\ protect_floor = 0, protect_bias = 16,
\ dering = -80, dering_weight= 1.0, dering_floor = 8, dering_bias=12,
\ detail_floor = 10, EQ = 2,
\ warp_Y = false, warp_UV = false, exborder = false,
\ debug= "protect | dering | compareH|V | showall",
\ cropx=64, cropy=32
\ )Hi
wenn ich das obige Script so aufrufe kommt folgende Fehlermeldung:
Import couldn´t open "C:\Programme\Avisynt\plugins\avsfilter.vdf.avs")
Was könnte denn da faslch sein??? -
avsfilter.vdf ... wo bitte wird das geladen? In einer der Skripte, die du mit "Import" lädst? Oder vielleicht in irgend einem Skript, das du dummerweise in das AviSynth-Plugins-Verzeichnis kopiert hast (Autoload-Plugins werden immer geladen, egal ob man sie braucht...)?
OK
den Fehler hab ich jetzt nicht mehr.
Jetzt kommt Dustv5 ist kein Avisynth 2.5 Filter. Heisst das, daß ich das Script nicht mehr nutzen kann ? Oder gibts eine neuere Version von Dust???
Wolli:) -
Soweit ich weiß gibt es keine neue Version von "Dust", sollte aber gut funktionieren wenn du zuerst die "LoadPluginEx.dll" in deinen Script lädst.
Hi wo find ich die dll finde nirgendwo beim Googeln.
Wolli:) -
Bitte
Danke
aber er meckert trotzdem im Script von iip mmx an zeile 164 keine Ahnung warum
Habe eine iNtel 2 Core Quad 4x 2,4 GHZ
Wolli -
Exakte Fehlermeldung zitieren!
"Meckert irgendwas" hilft uns nicht, und hilft dir dann auch nicht.
Zur Zeit des letzten Updates des iiP-Scriptes gab es in den MaskTools noch den Parameter "useMMX=true/false". Spätere Versionen der MaskTools (und somit auch die heute aktuellen) haben diesen Parameter verworfen, verwenden intern immer "true", und können mit dem Parameter "useMMX" nichts mehr anfangen.
(==> das war ein Upgrade ohne Rückwärts-Kompatibilität.)Lösung: das iiP-Script nach "useMMX=true" durchsuchen, und jedes Vorkommen ersatzlos löschen.
(Hab' nämlich keine Lust, an diesem Dinosaurier-Script noch irgendwas zu ändern.) -
Ok
Ich nehme Seesaw der läuft, nur ich hätte es gerne etwas schärfer das Bild sieht so verwaschen aus kann LSF noch dranhänegen an Seesaw?
hier mal mein ScriptZitat# PLUGINS laden
LoadPlugin("C:\Programme\AviSynth\plugins\Degrainmedian.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\RemoveGrainSSE3.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\RepairSSE3.dll")
#LoadPlugin("C:\Programme\AviSynth\plugins\VagueDenoiser.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\Fluxsmooth.dll")
LoadPlugin("C:\Programme\AviSynth\plugins\mt_MaskTools.dll")
Import("C:\GK\SeeSaw.avs")mpeg2source("C:\GK\StarWarsEpisodeIIAngriffderKlonkrieger.d2v")
#Deblock(30)crop( 8, 120, -8, -120)
Tweak(sat=1.2)
a = lastb=a.degrainmedian(mode=2).FluxsmoothST(7,7)
#VagueDenoiser(threshold=0, method=2, nsteps=4, chromaT=0)SeeSaw(a,b, NRlimit=6, NRlimit2=7, Sstr=1.5, Slimit=5, Spower=5, Sdamplo=6, Szp=16)
GaussResize(704,336,p=75)
Gauss hatte ich drangehängt weil ich dachte würde dann schärfer aber is nicht.
Wolli:) -
Hi Dideé
das ist ein bisschen zu scharf:D welche Parameter bestimmen denn die Schärfe?
Wolli:) -
Das war das Ziel der Übung.
Alle.
NRlimit: absolutes Limit für Pixeländerungen durch den Denoiser.
NRlimit2: dito, aber für den halb-entrauschten Hilfsclip, auf dem geschärft wird.
Sstr: prozentualer Multiplikator für die Stärke der Schärfung.
Slimit: absolutes Limit für Pixeländerungen durch's Schärfen.
Spower: Exponent für den nicht-linearen Verlauf der Schärfung.
Szp: der "Nullpunkt" des nicht-linearen Schärfens. Pixeländerungen kleiner als Szp werden verstärkt, Änderungen größer als Szp werden abgeschwächt.
SdampLo: Dämpfung für die Verstärkung von sehr kleinen Pixeländerungen durch's Schärfen.
SdampHi: Dämpfung für die Verstärkung von großen Pixeländerungen durch's Schärfen.
bias: Prozentualer Anteil des nicht-entrauschten Clips an dem Hilfsclip.
sootheT: Prozentuale Stärke der zeitlichen Glättung der Schärfungs-Differenz.
sootheS: Prozentuale Stärke der spatialen Glättung der Schärfungs-Differenz.
Jetzt ist alles klar, oder?
Hi Dideé
schönen Dank für Deine Antworten.
Mein Problem ist nur das ich diese ganzen technsichen Begriffe nicht verstehe. Ich bin js froh das ich gerade mal ein Script auf die Beine bekomme, das acuh läuft, die ganzen Beschreibungen sind entweder in Englisch oder ich kapier sie nicht sorry.
Meine Frage ist an welchen Parametern muss ich in welchem Verhältnis was ändern um das Ergebnis schärfer oder weicher zu machen?
Ich gehe doch mal davon aus,das diese Parameter alle in einem bestimmten Verhältnis zueinander stehen.Danke
Wolli:) -
Mal eine zwischen frage in eurer Diskussion, wie kann ich hier an besten gegen das "Rauschen" vorgehen?
(Hab' nämlich keine Lust, an diesem Dinosaurier-Script noch irgendwas zu ändern.)Hab ich schon vor nem Halben Jahr bei der übername der "Didée Filter Collection" gemacht. Das Skript liegt im gleichen ordner, mit nem "_no_useMMX" dran.
EDIT: es hat Mittlerweise die endung "_PbRF"
