Heute angemeldet und drei nichtssagende Beiträge. Vermutlich Spammer -> Account löschen.
VapourSynth in praktischer Anwendung
Hab gerade:
1. Python 3.3 32bit und Vavpoursynth r18 runtergeladen und installiert
2. eine Python command line geöffnet und
aufgerufen, Ergebnis:ZitatVapourSynth Video Processing Library
Copyright (c) 2012 Fredrik Mellbin
Core r17
API r3
okaaay,... ich hab definitv r18 runtergeladen und die Datei die ich installiert habe hies auch: vapoursynth-r18.exe
Wollte dann das Beispiel von http://vapoursynth.com/doc/gettingstarted.html antesten, hab es also entsprechend meinem System angepasst:Code
Alles anzeigenimport vapoursynth as vs # needed for stdout import sys # create a core instance core = vs.Core() # load a native vapoursynth plugin # you should use absolute paths as the working directory may not be what you think it is core.std.LoadPlugin(path=r'G:\Hybrid\avisynthPlugins\ffms2.dll') # load an avisynth plugin # the loaded functions will always end up in the avs namespace core.avs.LoadPlugin(path=r'G:\Hybrid\avisynthPlugins\UnDot.dll') # open a video file; ret is now a clip object ret = core.ffms2.Source(source='H:\TestClips&Co\test.avi') # apply the undot filter to the video ret = core.avs.UnDot(clip=ret) # output the clip to stdout with y4m headers (useful for x264 encoding/mplayer playback) ret.output(sys.stdout, y4m=True)
mit dem Ergebnis:ZitatPython 3.3.0 (v3.3.0:bd8afb90ebf2, Sep 29 2012, 10:55:48) [MSC v.1600 32 bit (In
tel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> # needed for stdout
... import sys
... core = vs.Core()
... # you should use absolute paths as the working directory may not be what you
think it is
... core.std.LoadPlugin(path=r'G:\Hybrid\avisynthPlugins\ffms2.dll')
The plugin 'FFmpegSource 2 for VapourSynth' uses API R2 which is deprecated. Upd
ate to keep it working in future versions.
... # the loaded functions will always end up in the avs namespace
... core.avs.LoadPlugin(path=r'G:\Hybrid\avisynthPlugins\UnDot.dll')
... ret = core.ffms2.Source(source='H:\TestClips&Co\test.avi')
Traceback (most recent call last):
File "<stdin>", line 2, in <module>
File "vapoursynthpp.pyx", line 1048, in vapoursynth.Function.__call__ (src\cyt
hon\vapoursynthpp.c:15779)
vapoursynth.Error: "Source: Can't open 'H:\\TestClips&Co\test.avi'"
... ret = core.avs.UnDot(clip=ret)
NameError: name 'ret' is not defined
er playback)
... ret.output(sys.stdout, y4m=True)
>>>-> 1. Weiß einer was ich falsch mache?
2. muss man die Python-Skripte immer in der Konsole eingeben, oder kann man die auch die Avisynth Skripte in eine Datei Speichern und dann diese Pyhton zu futtern geben?Cu Selur
Das mit der r18 könnte vielleicht ein Flüchtigkeitsfehler sein, dass der Autor hier vergessen hat zu updaten... aber in der Versionsausgabe wird schon auf eine API r3 hingewiesen.
Laut Fehlermeldung sieht es so aus, dass deine FFMS2.dll veraltet sei (deprecated API R2). Aber vielleicht hat die auch bloß Probleme, eben dieses AVI zu öffnen...
Wie in der Python-Dokumentation beschrieben, die in der VapourSynth-Dokumentation verlinkt ist, kannst du das Skript speichern als *.py (wird mit Konsolenfenster ausgeführt) oder *.pyw (Konsolenfenster wird unterdrückt).
Das war anno 2004,da hat mein Krümmel das PC-Heft Computer Bild nach Hause gebracht.
Hab da natürlich auch reingeschaut.....was sehe ich...die perfekte Anleitung für die ersten Schritte mit Avisynth.
Ja, der Artikel hieß doch: "Kann denn Avi Synthe sein?" Da wurde auch der Deinterlacing-Spezi scharfis_brain genannt. -
hdst: sicher das Du im richtigen Thread bist?
LigH:
r725 -> gleicher Fehler
r742 von http://forum.doom9.org/showthread.php?p=1611719#post1611719ZitatTraceback (most recent call last):
File "test.py", line 13, in <module>
ret = core.ffms2.Source(source='H:\TestClips&Co\test.mp4')
das avi ist eigentlich nur Xvid video und mp3 audio, also nichts irgendwie besonderes.
r739 von http://forum.doom9.org/showthread.php?p=1607732#post1607732 (VapourSynth-only plugin) -> gleicher Fehler=> falls jemand hier im Board VapourSynth erfolgreich nutzen kann wäre es schön, wenn er was dazu sagen könnte.
Momentan sieht VapourSynth nicht wirklich gut aus. Ich meine wenn schon nicht mal das Beispielskript geht, will ich über komplexere Sachen gar nicht erst nachdenken.Cu Selur
Sicher, dass dein Zitat stimmt? Du lädst da plötzlich ein MP4, aber der Fehler ist immer noch mit AVI?
Versuch mal "ret = core.ffms2.Source(source=r'H:\TestClips&Co\test.avi')".
sneaker2: Das war es! dann spammed er einem die Konsole voll
LigH: hab mal alle möglichen Quellen ausprobiertnebenbei sei auch erwähnt, dass 'ret = core.avs.UnDot(clip=ret)' auch nicht passt, muss 'ret = core.avs.UnDot(ret)' heißen,..
-> die Dokumentation bei http://www.vapoursynth.com/doc/gettingstarted.html ist also wohl eher abschreckend als hilfreichDanke auf jeden Fall an die Helfer!
Nur mal so am Rande:
Nutzt hier mittlerweile irgendwer Vapoursynth?
Nutzt ihr die 64bit oder die 32bit Version?Hat jemand eine Filtersammlung von:
a. 64bit AvisynthPlugins (damit man nicht jedes per Hand runterladen muss) ?
b. 64bit VapoursynthPlugins (damit man nicht jedes per Hand runterladen muss) ?Cu Selur
Aus den News verschoben; du hattest vor längerer Zeit schon mal gefragt (deswegen auch kleine inhaltliche Anpassung)...
Ich nicht, nein. Bin bisher immer noch nur bei AviSynth, und nicht mal schlüssig, ob sich da Plus lohnt, wenn es bisher noch kein MTMode unterstützt.
Ich auch nicht. Immer noch AVIsynth. :cool:
Von Avisynth+ gibt's doch auch ne Version die MTMode unterstützt, aber da sehe ich auch noch nicht wirklich die Vorteile die es bringt.
Die MT-Variante von AviSynth+ ist dann aber nicht auf der offiziellen Website? Ich such mir grad 'nen Wolf im englischen Forenbeitrag...
Für VapourSynth fehlt mir bisher noch die Notwendigkeit. Auch wenn die VfW-Schnittstelle eigentlich veraltet ist, ist sie aber doch immer noch komfortabel.
Nein, ist nicht auf der Website, die AVS+ MT-Version ist auch nicht sehr stabil. Wenn du es versuchen willst, hier ist der relevante Forumbeitrag. -
Ich hab vor kurzem mal versucht den QTGMC mit AVS+ MT zum laufen zu kriegen. Und er lief, aber dummerweise nur mit 1/3 der Geschwindigkeit von AVS 2.6 MT.
An Plugin .dlls hatte ich mir die neuestem MT-fähigen Versionen rausgesucht und die ganzen SetFilterMTMode() Anweisungen, wie von Ultim empfohlen, per Autoload-Script eingebunden.
Aber weil das Ergebnis so schlecht war hab ich mich dann nicht mehr weiter damit beschäftigt. Vieleicht lags nur an einem Plugin was mit AVS+ nicht ganz rund läuft... -
Ich experimentiere gerade mal wieder etwas mit Ubuntu. Die letzte AvxSynth-Version stammt von 2013, keine Ahnung ob die gut läuft. Unter Windows habe ich Avisynth nur für das laden von Files aller Art sowie für trim(), Resize, schwarze Balken und so'n einfaches Zeug genutzt. Einzig bei einer ganz bestimmten Aufnahme aus dem TV-Programm yadif() als Deinterlacer genutzt. Nun frage ich mich ob sich das mit Vapoursynth hinbekommen lässt. Ich kann weder Python noch eine andere Programmiersprache.
Ich werde vermutlich auch mal Avisynth in Wine austesten - soll ja auch laufen.
Sollte mit Vapoursynth ohne Probleme machbar sein. -
Gibt es mittlerweile eigentlich ne Möglichkeit Vapoursynth mit einer portablen Python Version zu nutzen?
And now for something completely different ...
Es soll ja Sachen geben, die in VapourSynth deutlich besser funktionieren als in AviSynth. Wer aber Interesse daran hätte, die Ausgabe von VapourSynth noch in AviSynth weiter zu verarbeiten, der kann dafür nun auch VapourSource benutzen.
Da ich leider weder AvxSynth noch Avisynth@Wine halbwegs brauchbar unter Linux zum Laufen gebracht habe, wollte ich nun mal VapourSynth versuchen. Ich habe aber keine Ahnung von Python.
Kann mir jemand nur für einen ersten Test ein Skript posten mit dem man einfach eine Datei mit Audio- und Videospur öffnet mit Trim-Befehl drin?
