Hallo zusammen,
ich versuche nun schon seit geraumer Zeit einen Film zu encoden und bekomme immer einen bbMPEG error an der selben stelle.
bbMPEG error
Input file C:\Film Dateien Temp\Encoded_Video_CCE_PAL.mpv was not found.
kann mir jemand einen Tip geben, was hier falsch läuft oder was ich vielleicht falsch mache.
Andreas
Hier noch mein LOG File:
WNASPI32.DLL 0.0.0.0
- 09.03.2004 18:14:56
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.1 build 3
Initializing
- E:\Filme\DVD RIP\VTS_01_0.IFO
- E:\Filme\DVD RIP\VTS_01_1.vob
Initializing finished.
- 09.03.2004 18:14:59
- DVD2AVI
Creating DVD2AVI INI file:
- d:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"d:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Film Dateien TEMP\DVD2AVI_Project_file] -IF=[E:\Filme\DVD RIP\VTS_01_1.vob]
Framerate: 25000
DVD2AVI processing done.
- 09.03.2004 18:29:13
- Free on drive C: 5134.42 mb
- Free on drive d: 1371.51 mb
- Free on drive E: 3894.00 mb
- AUDIO Extraction
Found AC3 stream id: 0x81
Filename: E:\Filme\Audio\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Framerate: 25000
Audio extraction finished.
- 09.03.2004 18:39:29
- Free on drive C: 5133.81 mb
- Free on drive E: 3516.87 mb
- AUDIO conversion
Encoding Audio. Filename: E:\Filme\Audio\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"d:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\Filme\Audio\Extracted_audio_1.ac3" -output "E:\Filme\Audio\Encoded_audio_1.mp2" -logfile "E:\Filme\Audio\Encoded_audio_1.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround2 -f on -g max ) -2lame( -e -b 192 -m s )
Audio conversion of E:\Filme\Audio\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 09.03.2004 19:03:10
- Free on drive C: 5133.80 mb
- Free on drive E: 3328.38 mb
- Converting Pictures
Converting: d:\Programme\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 09.03.2004 19:03:20
- Free on drive C: 5133.00 mb
- Free on drive E: 3328.44 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 2497628364
AudioSectors: 200781980
VideoPAPO: 35579376
ScanOffsetBytes: 0
SeqAligningBytes: 0
DVDBytes: 0
VideoEndHeader: 12
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 600.00
PureMPEGStream: 2261266996.00
Seconds: 8254.28
CalcMPEGStream: 2261266996.00
Frames: 205982
CDSize: 800.00
Number of CDs: 3
Cut point 795.00
Variable Settings:
Frames: 205982
Anti Noise Filter: Off
Passes: 4
Image Quality: 20
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 1181
Max. bitrate: 2553
Avg. Bitrate: 2191
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("d:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL")
mpeg2source("C:\FILMDA~1\DVD2AV~1.D2V")
LoadPlugin("C:\Winnt\System32\VSFilter.dll")
BicubicResize(448,320,1/3,1/3,20,72,680,432)
VobSub("D:\Film Subs\VTS_01_0")
AddBorders(16,128,16,128)
Import("C:\Film Dateien TEMP\ResampleAudio.avs")
ResampleAudio(44100)
ConvertToYUY2()
----AVS End----
Closing program
CCE Max Speed: 0.010
Video Encoding finished.
- 09.03.2004 19:04:39
- Free on drive C: 5132.27 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: d:\Programme\DVD2SVCD\bbMPEG\default.ini
- 09.03.2004 19:04:42
- Free on drive d: 1371.50 mb
Executing RunbbMPEG. Commandline:
"d:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Film Dateien TEMP\ChangeCDPicture.bmp.mpg"
- 09.03.2004 19:04:52
- Free on drive C: 5132.22 mb
- Free on drive E: 3328.43 mb
- 09.03.2004 19:04:55
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mb
"d:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\Filme\Mpeg2\bbMPEG_Muxed_File.mpg"
- 10.03.2004 08:38:22
Initializing
- 10.03.2004 08:38:28
- Free on drive C: 5082.21 mb
- Crash Recovery
- Restarting from: Muxing and Cutting
- 10.03.2004 08:38:30
- Free on drive C: 5082.20 mb
- 10.03.2004 08:38:33
- 10.03.2004 08:38:37
- Free on drive C: 5082.19 mb
- 10.03.2004 08:38:40
- Free on drive C: 5082.18 mb
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
bbMPEG failed. Exitcode: 3221225786
- 10.03.2004 09:13:59
- Free on drive C: 5080.76 mb
- Free on drive d: 1231.54 mb
- Crash Recovery
- Restarting from: Video encoding
- 10.03.2004 09:14:00
- Free on drive C: 5080.75 mb
VideoPAPO: 35579376
ScanOffsetBytes: 0
SeqAligningBytes: 0
DVDBytes: 0
VideoEndHeader: 12
SubtitleSectors: 0
Seconds: 8254.28
Frames: 205982
CDSize: 800.00
Number of CDs: 3
Cut point 795.00
Variable Settings:
Frames: 205982
Passes: 4
Image Quality: 20
Min. bitrate: 1181
Max. bitrate: 2553
Avg. Bitrate: 2191
---AVS Begin---
ConvertToYUY2()
----AVS End----
Closing program
- 10.03.2004 09:15:24
- Free on drive C: 5131.00 mb
- 10.03.2004 09:15:27
- Free on drive C: 5130.99 mb
- 10.03.2004 09:15:44
- Free on drive C: 5130.98 mb
- 10.03.2004 09:15:48
- Free on drive C: 5130.97 mb
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
- 10.03.2004 09:16:18
- Crash Recovery
- Restarting from: Picture conversion
- 10.03.2004 09:16:28
- Free on drive C: 5130.96 mb
VideoPAPO: 35579376
ScanOffsetBytes: 0
SeqAligningBytes: 0
DVDBytes: 0
VideoEndHeader: 12
SubtitleSectors: 0
Seconds: 8254.28
Frames: 205982
CDSize: 800.00
Number of CDs: 3
Cut point 795.00
Variable Settings:
Frames: 205982
Passes: 4
Image Quality: 20
Min. bitrate: 1181
Max. bitrate: 2553
Avg. Bitrate: 2191
---AVS Begin---
ConvertToYUY2()
----AVS End----
Closing program
- 10.03.2004 09:17:34
- Free on drive C: 5130.94 mb
- 10.03.2004 09:17:37
- Free on drive C: 5130.93 mb
- 10.03.2004 09:17:44
- 10.03.2004 09:17:46
- Free on drive C: 5130.92 mb
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
bbMpPEG error bei DVD2SVCD
Ist den die Datei (C:\Film Dateien Temp\Encoded_Video_CCE_PAL.mpv) auch vorhanden?
hi AnGo76
hast Du für alle Dateien die bearbeitet werden den selben Ordner genommen?
bbmpeg findet die encodierte Datei (mpv) nicht.
Ich geh immer unter RK Misc auf den Button "Default output Folder" und dann auf Set default output Folder > damit ist gewährleistet dass alle zu bearbeitenden Dateien im selben Ordner sind. bbmpeg muxt ja Ton und Video zusammen. Und eben diese Videosequenz (mpv) findet er nicht.
by
Chrille -
Hallo Chrille und Raschi,
ich habe in DVD2SVCD verschiedene Speicher Orte angegeben, da ich nicht genug Speicherplatz auf einer Festplatte habe.
Das hat aber bis jetzt auch immer einwandfrei hingehauen.
Die Datei die er nicht findet, ist aber auch nicht vorhanden.
Ich habe die Sache mal beobachtet. CCE encoded zuerst das Change CD Picture, dauert ja nicht lange und hört dann auf. Dann startet sich gleich bbMPEG ohne das der Film selber encoded wird und die Fehler Meldung erscheint. CCE fängt nicht an den Film zu encoden.
Keine Ahnung was da falsch läuft.
Das Problem ist aber nur bei diesem Film, woanders läuft D2S normal durch.
Ich habe momentan den CCE manuell gestartet. Keine Ahnung ob ich es richtig gemacht habe.
Habe einfach unter File, Open Project, das File CCE_Project_file.ecl aufgerufen und dann auf Encode gedrückt.
CCE hat die beiden AVS Files ChangeCDPicture.bmp.avs und AviSynth_Script_file.avs ins Fenster geholt und encoded seitdem.
Falls ich hier was falsch gemacht habe, sagt es mir bitte. Dann kann ich mir nähmlich die Zeit sparen die CCE noch braucht.
Für Vorschläge und Lösungen warum CCE nicht anfängt den Film zu encoden und diesen Punkt einfach überspringt würde ich mich freuen.
Andreas -
Seconds: 8254.28
Closing program
- Crash Recovery
- Free on drive E: 3328.43 mbDas die mpv nicht erstellt wurde ist bei dem Log relativ wahrscheinlich. Die äußerst geringe Geschwindigkeit des CCE ist aber irritierend.
Du solltest Dir die FAQ von Gerti ansehen (sollte hier irgendwo als Wichtig-Thema sein). Wichtig ist auch die Version des CCE. -
Hm...irgendwie irreführend das mit der Aufsplittung. Bei drei CD's solltest Du auch beachten, dass der Platz auf der Partition reicht. Wenn der CCE merkt das der Platz nicht ausreicht, bricht er auch ab. Wenn z.B. der erstellte mpv File (bei drei CD's min. 2,1 GB) + bbmpeg die fertigen Teile auf der selben Partition erstellen soll, kämen dann nochmal ca. 2,4 GB zu. Würde in Summe dann min. 4,5 GB machen.
Ich würde das mit den verschiedenen Ordner nochmal überprüfen und ggf den nötigen Platz mit einkalkulieren.
by
Chrille -
Hallo nochmal,
das mit dem Aufsplitten ist kein Problem, ich hab schon öfters 3 CD Filme encoded und der Platz ist ausreichend.
Probleme macht CCE (Version 2.67).
CCE schließt sich gleich nachdem das Change CD Picture encoded wurde.
D2S macht dann gleich mit bbMPEG weiter.
Wenn zuwenig Platz auf der Platte wäre, würde CCE oder bbMPEG erst dann abbrechen wenn der Speicherplatz aufgebraucht ist.
Andreas -
Das ist jetzt reine Vermutung! Der CCE 2.67 hat doch glaube ich als Standardendung für MPEG2 m2v und nicht wie die Vorgängerversionen mpv. Vielleicht bringt ja das den Fehler! Aber wie gesagt, ist jetzt reine Spekulation. Die Endung kann man im CCE ändern.
keine Ahnung ob das der Fehler ist, aber bis jetzt hat es ja immer funktioniert. Und es funktioniert ja auch bei anderen Filmen.
Jetzt habe ich noch eine Frage, da ich ja gerade den CCE manuell laufen habe.
Ich habe den CCE heute morgen manuell gestartet. Da ich keine Ahnung habe, ob ich es richtig gemacht habe, würde ich mich freuen wenn Ihr mir kurz sagen könntet obs so passt oder nicht.
Falls ich hier was falsch gemacht habe, da ich Einstellungen nicht gemacht habe, die normaler weise DVD2SVCD macht, sagt es mir bitte. Dann kann ich mir nähmlich die Zeit sparen die CCE noch braucht.
Ich hab mir das nämlich so vorgestellt.
Ich schalte den CCE selber ein (so wie ich es gemacht habe) und lasse ihn den Film encoden. Gehe nach Beendigung wieder zu DVD2SVCD zurück und benutze die Recover Funktion in dem ich D2S mit muxing and cutting weiter machen lasse und hoffe das das Endprodukt 3 mpeg und 3 Images Files sind mit der gewohnten Qualität.
Andreas -
ich denke das bereits alle Einstellungen in der ECL vorhanden sind
Hallo zusammen,
hab es gestern noch mal mit der recover Funktion probiert. Und auf einmal hat es geklappt.
Keine Ahnung warum es auf einmal funzt.
Aber trotzdem Danke für die Hilfe.
Andreas
