DVD-RB 1.10.3 Pro ist raus.
Zitat von jdobbsAlles anzeigenHISTORY:
August 11th, 2006 (v1.10.3)
CHANGES MADE TO PRO VERSION- Added routines to recognize and ignore extraneous files in the source directory -- including unreferenced VTSs that serve no purpose except to occupy space.
- Fixed "Runtime Error 6" that can occur during rebuild when dealing with very small M2V files under specific conditions.
- Corrected a problem in which, under specific circumstances, ILVU segments for angles that are encoded with CCE may not be encoding with necessary GOP restrictions.
- Fixed an error in which pointers in the SML_AGLI table could incorrectly set some block pointers to NEXT_ILVU + 1 rather then NEXT_ILVU. This could cause a momemtary audio or video "jump" when switching angles.
- Tweaked several ILVU settings to ensure strict compliance.
- Added code to verify paths in INI. This will prevent the occurance of Runtime Error '52' and Runtime Error '76' when invalid paths are manually entered into the INI file.
- Fixed a bug in which the completion status bar may not be updated to reflect 100% at the end of PREPARE.
- Updated the installer to include AVISYNTH v2.5.6. It will NOT, however, overwrite your existing AVISYNTH installation so it it recommended that if you want to upgrade to this newer version -- you must first uninstall AVISYNTH using the Windows Control Panel.
- Added Rebuilder version information to AVS, INF, and LOG files to make debugging easier.
- Corrected a bug in which detection of the AutoQMatEnc path may not have worked properly on some non-English systems.
- Corrected an error in which "Runtime Error '52'" may occur at startup on systems that use drives other than "C:" as the root.
- Fixed a command line incompatibility issue with early versions of QuEnc.
- Added an optional alternate output path for ISO creation. By adding "ISO_OUTPUT=" (and a path) to the "[Paths]" area of the REBUILDER.INI you can redirect output to a path or drive other than the output directory.
- Updated the installer to include the latest QuEnc v0.71.
- Fixed other minor/cosmetic bugs.
Cu Rippraff
