Seit dem 7.6.2009 ist Version 1.2.2 auch auf http://www.koepi.info erhältlich, bisher noch nicht mit VAQ-Patch.
XviD 1.x - aktuelle Version
Danke an Hagbard2305 für den Hinweis:
Es gibt auch immer wieder mal ein SVN-Build Version 1.3 mit VAQ-Patch.
Hatte ich schon wieder vergessen, weil Koepi bisher noch nicht auf 1.3 umsteigt.
Alexins/ Isibaar hat seinen 1.3.0er CVS-Build aktualisiert. Changelog:
* Use -maltivec only to compile the sources containting altivec code. GCC may otherwise produce altivec code on non-altivec PPC (thanks to Frederik Wikstrom) (2009.06.09)
* Additional sanity check when reading stats file (2009.07.01)
* no_exec stack patch for x86_64 too by Michal Schmidt (2009.09.16)
* Removed inner nested AC_CHECK_LIB test for pthread_join (autoconf-2.64 compatibility) (2009.10.6) -
Xvid 1.3.0-rc1
ZitatThis is Xvid 1.3.0-rc1 release candidate.
This is the first release candidate of the Xvid 1.3 series. It is API
compatible with the previous 1.2.2 stable release.Changes since 1.2.2:
* xvidcore
- Added PSNR-HVS-M quality-metric plugin
- Variance masking as new adaptive quantization option
- MT decoder deblocking filter
- Improved encoder multi-threading allowing more threads and better scaling
- Decoder threads API extension
- PSNR-HVS-M as optional D-metric for R-D optimizations
- Noexec-stack security patch also for x86_64 asm code
- Added new slice coding feature
- App-level encoder multi-threading support (xvid_encraw)
- Signalling of FourCC to decoder for better bug detection
- Changed semantics of frame_drop ratio API option
- Improved decoder robustness on resync markers in BVOPs* VFW frontend
- Increased allowed max bitrate
- New 'HD 1080' preset
- Added new MPEG4 simple profile levels
- VHQ metric GUI option
- Independent slice coding widget
- Selectable adaptive quantization method
- Fix for handle leak problem
- Minor GUI cosmetics* DShow/MFT frontend
- Tray icon to access filter properties
- Added MFT API support
- Shared cpu_flags/num_threads settings with VfWhttp://www.xvid.org/
Leider hab ich noch kein Build zum testen gefunden. -
Kann mir jmd erklären wie es die 1.3 schon ein Jahr geben kann?
Und zwar auf xvidvideo.ru -
Das sind die Alpha Versionen, da ist das wichtigste nicht dabei~
ich meine auch, das er Isibaar ist~http://list.xvid.org/pipermail/xvid…ber/006232.html
Das würde ich aber echt gerne testen und hoffe das RC1 Build gibts bald irgendwo, auch mit neuer Encraw~
Auf Jawors Seite gibt es eine Binary.
Allerdings sind sowohl MT als auch Tray Icon für mich nicht erreichbar.
Also scheint es wohl eine "Stripped down" Version zu sein.
Immer dieses Hickhack mit den Versionen.
Was waren das noch für schöne Zeiten als ein Koepi Build für amtlich galt ;D.
Hier der Link zu Jawors Builds:
http://jawormat.republika.pl/xvid.html -
Danke für die Infos. Aber leider verwirren dich mich nochmal.
Eine Neuerung ist:
ZitatVBV parameters can be adjusted in the "unrestricted" profile
Aber ich dachte VBV funktioniert bei Xvid nicht. Oder wurde das gefixt und ich habe es nicht mitbekommen?
EDIT: Es wurde gefixt ohne dass ich es mitbekommen habe. Im mtk profil lässt sich sogar qp nutzen.
PSNR-HVS-M: Wer mag mir das mal erklären?
Sliced Threads: Nur Speed oder auch Quality Impact wie bei x264? -
XVID 1.3 final ist draußen. Sowohl bei/via "Koepi"
(http://www.koepi.info/xvid.html)
als auch bei "Jawor"
(http://jawormat.republika.pl/xvid.html)
Wer Windows 2008 (R2) benutzt sollte erstmal davon absehen die 1.3.0 final zu installieren.
Konnte auf mehreren Installationen von 2k8 Abstürze reproduzieren.Code------------------------------------------------------------ Error opening source ------------------------------------------------------------ Exception has been thrown by the target of an invocation. FFVideoSource("%source_file%", cachefile="%working_dir%%source_name%.ffindex") usw
Keine Probleme mit der 1.2.x oder 1.3.0 RC1.
Der Fehler tritt sowohl mit Jawors als auch dem bei Koepi verlinkten Build auf.
Virtualdub meldet: Error decompressing video frame 0: The source image format is not acceptable. (error code -2)
Neue "bugfix"-Version bei/von Jawor auf seiner Seite
Gruß,
Olnima -
1.3.1
ZitatThis is Xvid 1.3.1 bugfix release. It fixes and replaces the previous 1.3.0 stable release.
Changes since 1.3.0:
xvidcore libraryEnabled noexec stack for both elf and elf32 obj format for better NASM compatibility
Fixed edging bug for non-mod16 image dimensions
Generated configure scripts with more up-to-date autconf version
Fixed error with pthread check in configure.in scriptDShow/MFT frontend
Disabled rgb_flip for MFT decoder
Modified icon/gui graphics for better visibility
Changed VC8 project files to use static LIBCMT runtime -
1.3.2
ZitatThis is Xvid 1.3.2 bugfix release. It fixes and replaces the previous 1.3.1 stable release.
Changes since 1.3.1:
xvidcore libraryUpdated implementation of IDCT/FDCT to match error spec of MMX/SSE code
Added "make info" to unix Makefile
Removed debian directory from release tarballs
Made multi-threading (pthread support) switchable at compile timeVFW frontend
Minor GUI changes
DShow/MFT frontend
GUI cosmetics
Updated MSVC project files with seperate build configs for MFT-enabled binary -
Koepis neuer Installer bringt einen neuen Mini-Encoder mit, verschiebt xvid_encraw in ein "Advanced"-Verzeichnis, und korrigiert auch die erheblichen Probleme, die der DivX-Installer mit seinen eigenen Splittern für AVI und eingeschränktes MKV verursacht; besonders in 64-bit-Systemen, wo ein nicht existierender Splitter registriert wird.
Zitat von KoepiA new Xvid version is available, 1.3.2. It is mainly a bugfix release mainly for non-x86 and Unix users. But also, for the Windows users the new installer has some interesting features. In new installations, the tiny encoder xvid_encraw will be put into a new sub-directory "Advanced". For the ease-of-use, a new tool is included as well - Xvid MiniConvert. It will take most playable content and convert it to Xvid with MP3 audio in .avi containers. The installer also fixes a small annoyance which the DivX installer causes - it installs its own .avi and limited .mkv splitter and disables other splitters for these formats. This leads to the situation that many files can't be decoded properly. The situation is even worse on x64 systems, where that splitter is registered but totally missing. The new Xvid installer fixes this issue. Thanks Michael for the new installer and these nice additional tools and features!
1.33
This is Xvid 1.3.3 bugfix release. It replaces the previous 1.3.2 stable release.Changes since 1.3.2:
* xvidcore
- Improved MinGW and Cygwin compilation support
- Fixed possible encoder crash when Turbo+BVHQ+Qpel options are combined
- Added support for GNU Hurd as target OS
- Patch for QNX support
- Fix for possible overflow in Trellis quantization* VFW frontend
- Minor GUI changes* DShow/MFT frontend
- GUI cosmetics
- Switchable tray icon* Example programs
- Fixed bug in xvid_encraw PGM header parser
- Fix out of bound access to framestats struct in xvid_encraw -
El Heggunte im VideoHelp-Forum hat Xvid 1.3.4 als VfW-Codec und xvid_encraw compiliert. Zusätzlich soll diese Codec-Version auch das erweiterte Codec-Interface in VDFilterMod r13+ (als Output-Plugin) unterstützen.
Xvid 1.3.5 wurde veröffentlicht.
Zitat von hajj_3Changes since 1.3.4:
xvidcore library
- AmigaOS build patch by Fredrik Wikstrom
- Support for applevel multithreading mode also for AVI output in xvid_encraw
- Set interlacing flag in decoder correctly
VFW frontend- Re-add support to decode raw YV12 input FourCC video
- Fix: Produce debug output only when debug option is enabled
DShow/MFT frontend- Fixed bug in thumbnail creation on Windows 7
- Fix output buffer stride calculation in MFT
- Setting interlaced flags on output pins correctly in DirectShow and MFT
- Corrected pixel aspect ratio support in MFT
https://downloads.xvid.com/downloads/Xvid-1.3.5-20171208.exe
CLI-Programme (MinGW-Win32/GCC 7.2.0) gibts via MediaFire. War überraschend einfach...
_P.S.:
Welche Nutzungsbedingungen von MediaFire könnte ich damit verletzt haben? Download wird blockiert ... lass ich mir mal erklären. Bis dahin: Anhang im VideoHelp-Forum
