Es gibt eine neue PgcEdit 0.5.0 beta 9, die auch BoV unterstützen soll.
Zu bekommen hier, Windows-Version ganz unten, Linux-Nutzer brauchen nicht so weit zu scrollen.
Diskussion im engl. Forum.
Cu Rippraff
PgcEdit - Aktuelle Version
PgcEdit 0.5.0 beta12 is available
Well, this beta should be the last one before the final release.
As far as I know, this version is stable. The aspect ratio problem in the preview and menu editor is fixed, as well as a couple other bugs (including the PTT table bug reported by CoNS).Der final wird aber nochn bissl dauern da nochn paar bugs dazugekommen sind
PgcEdit 0.5.0 beta13 is available
Beta 13 is an attempt to fix the problems with the parsing of menubuttons/BOVs encountered by Wheelie4 and M7S.
I don't have a DVD with such problem, so, the bugfix was somewhat a blind edit. It may, or may not work.@Wheelie4 and M7S: Could you check it with your 'problematic' DVDs? Thanks.
Number of streams. Yes and no. It ia actually possible to search for the number of streams defined at the PGC level, and fix the total number of streams in VTSI_MAT with the Fix Streams macro.
But I writed this macro with a request of 2COOL in mind, and it is not possible to add a stream for now. Only to remove unnecessary streams left after a strip.
I'll change that immediately. 0.5.0 final will have a macro that will work in both situations.
So, the correct procedure will be: change the streams assignments at the PGC level, then call the macro. If some streams are added, you will need to edit the streams attributes as well.
[EDIT:] Done. -
PgcEdit v0.5.0 released
Changelog:
A. BOV (Buttons Over Video in Title domains) support:
- Replaced the executable button_dump.exe bt a Tcl/Tk function, able to
parse the menu buttons in menu domains. The menu buttons informations are
therefore available also for Macintosh pre-OSX platforms.
- Added "File->Find BOVs" and "Options->Automatically Launch BOV finder when
a DVD is opened?" to find the BOVs at startup.
- "Utilities -> Show Menu Buttons or BOVs" works now also for Title PGCs.
- Added "Show BOVs" popup menu in the PGC selector on title PGCs.
R. Removed the "Options/Show libdvdread warnings when parsing menu buttons?".
A. "Fix number of streams in VMGM/VTSI_MAT tables" macro to change the number
of streams in the VMGM_MAT and VTSM_MAT tables according to the number of
streams enabled in the PGCs.
A. Domain Streams Attributes check now if the current number of streams match
the number of streams enabled in the PGCs.
A. Domain Streams Attributes allow now to edit the audio stream types and
parameters. (Still no support to edit the karaoke parameters.)
A. Open DVD: If there are empty VOB files, an option to delete them is now
presented to the user when the DVD is loaded.
A. Added a Burn DVD/Create ISO toolbar icon. (Windows only)
A. Added some missing credits and thanks in the About dialog.
E. Kill Playback macro: New algorithm to determine if it is safe to use the
macro. It is safe to kill playback if there are no menu buttons, and if
there are no cell commands jumping outside of the current PGC.
E. Blank Out PGCs in Domain: The "Kill Playback only when it's safe" option
now uses the new Kill Playback macro.
E. Cell type flag SCR Discontinuity (System Clock Reference) renamed to STC
Discontinuity (System Time Clock). (Recommandation of Mpucoder)
E. Burn DVD: The MenuShrinkBackup is now removed automatically from the DVD.
E. Added the audio and subpic stream IDs in Domain Streams Attributes GUI and
in Info -> Streams.
F. PgcEdit_Preview.exe v1.6 by Jeanl. Fixes an aspect ratio bug with VCD and
SVCD resolutions, and another one with garbage addeded in the bottom of
the image when the vertical resolutions was not a multiple of 32.
F. When a cell is reassigned or blanked, the Seamless Joint flag is now
cleared.
F. Trace mode: The target of LinkPTT commands was wrong (was pre-commands of
the PGC instead of target chapter.)
F. Trace mode: A NOP command in a menu button or BOV is now ignored.
F. Highlight Target/Jump to Target did not work in some cases with CallSS.
F. Menu buttons viewer bug: After selecting another frame with the < and >
buttons, the background image was not displayed for VMGM menus.
F. Fixed a bug with the Video Attributes display. The resolution, bitrates
and 'top & bottom cropped' flags were wrong. The saved attributes were
OK, though.
F. Fixed a bug when writing a PTT_SRPTI table containing PTTs assigned to
program 0. Yes, I've seen a DVD with such bizarre things!
F. Fixed a bug occurnig after a Delete Program. The program map table was
not padded to an even number of bytes.
F. Misc. little bug fixes. -
doch. im engl. forum.
Zitat von roizwith, at last, the menu buttons editor (and a couple bugfixes).
jaaawoll! das is doch was. :cool: -
PgcEdit v0.5.1 beta 3 released
Changelog:
v0.5.1 beta 2:
- Fixes the two bugs in the menu editor reported by jeanl and blutach.
- Allow to right click on a button in the viewer to go in the editor.
- Fixes the bug starting PgcEdit 0.5 standalone on Linux platforms.Fixes the bug discovered by Tobi (see above), and a small problem with the Group radiobutton being highlighted in red after a Delete Button, even when the All Groups mode was current.
PgcEdit v0.5.1 released
Changelog:
A. Menu Buttons/BOVs Editor (still not totally finished, but operational.)
F. Wrong display aspect ratio was used in the menu buttons viewer for group
types sharing modes "normal" + "letterbox".
F. Fixed wrong highlighted target/jump to target in menu domains: the target
was always in LU 1.
F. Moved the stream's VOB IDs from the Domain Streams Attributes to the PGC
Streams assignments GUI, where they should be. The streans IDs are now
hopefully corrects.
F. Linux standalone executables 0.5.0beta1 to 0.5.1beta1 were broken. The
sources were OK. V 0.5.1beta2 is the first working 0.5 standalone exe.
F. Fixed a bug in 'Delete last PGC in domain' in title domain. The new total
number of TTNs was wrong when a PGC sharing the same TTN number with
another one was deleted.
F. Small bug fixed that prevented to "Delete Last PGC in Domain" if the PGC
was created with "New Dummy PGC" during the same PgcEdit session. -
VERSION 0.5.2 BETA 4
-"links" ganz am anfang
- changelog such ich noch... -
Zitat von mad-eddy
[size=18]- changelog such ich noch...
PgcEdit: Version history
A. = Added feature
R. = Removed
E. = Enhancement
F. = Fixed bug0.5.2beta4 (April 9, 2005)
- E. Export and Import color lookup tables is now able to import/export RGB colors in ASCII format, and to import the colors from a Muxman project.
- E. Multiple errors messages when parsing the VOBs for menu buttons are now suppressed. Take care: one error message means that the whole VOB is not correctly parsed!
- F. Problem deleting the DLLs in the bin directory when uninstalling PgcEdit is now partially fixed. You will need to delete them manually.
0.5.2beta3 (April 9, 2005)
- A. Added an Configuration option in the virtual player setup to load the PGN (Program number) instead of the PTTN (Chapter number) in SPRM 7. Many software and hardware players are not standard compliant on this point.
- A. Added Export and Import buttons to save and load the color lookup table of the current PGC in the PGC Editor. File format: raw YCrCb color table.
- A. Added an option to display the popup menus when the right mouse button is released instead of pushed. This option is not recommended, though.
- A. A warning is issued when entering the menu buttons viewer if several sets of menu buttons are found in a cell. Currently, PgcEdit handles only the first set. A new option to optionally scan for multiple sets of BOVs has also been added in the 'Scan for BOVs' dialog.
- A. Added an option to store the PgcEdit_backup in the root folder of the DVD instead of in the VIDEO_TS folder. Useful to launch programs that doesn't work if there are illegal files in VIDEO_TS (like WinDVD).
- A. Added File->Incremental Backup. Renames the current PgcEdit_backup folder (adds the modification time and date), and creates a new PgcEdit_backup.
- E. File->Delete Backup(s) is able to delete the backups created by PgcEdit, VobBlanker, MenuShrink and Windows (Copy of ...), including incremental backups. TitleSetBlanker backups are not supported anymore.
- E. Burn DVD: Excludes the backups PgcEdit_backup*, VobBlanker_backup*, MenuShrinkBackup* and "Copy of *" from the compilation.
- E. Better error trapping for file I/O errors (copy, delete, rename, makedir). Now, a dialog pops up, allowing to retry the operation.
- E. Thanks to the demo version of the Tcl DevKit, the code is now a little bit optimized, and a couple of potential bugs have been fixed.
- F. The last VTS's title domain BOVs were never saved. Fixed.
- F. "Can't read "::buttons::butsinfo(*,hlendtime)": no such element in array" (and selendtime) errors when a new button was created are now fixed.
- F. Trace: When in a button command, LinkNextCell linked to the current cell, and LinkPrevCell linked to the current cell -2. Fixed.
PgcEdit v0.5.2 released
Changelog:
A. Added Export and Import options to save and load the color lookup table of
the current PGC in the PGC Editor. File format: raw YCrCb color table (64
bytes, with leading 0 before each color) or RGB colors in ASCII format.
The import function can also import the colors from a Muxman project, or
from VTS IFO file (the colormap of the first PGC is used).
also been added in the 'Scan for BOVs' dialog, and the scanning for sets
of buttons is optimized for speed.
correctly parsed!
E. When saving buttons or BOVs, the original highlight status is left
unchanged so that the animated highlights (for example, in Spiderman) will
now still be animated.
F. The total number of menu buttons or BOVs displayed in the PGC selector
label was not updated after a Remove Cell. Fixed.
F. Fixed a little bug in the "Options/Install/Associate PgcEdit with IFO (or
BUP) Files", when the association was already present, but was blank.
is now partially fixed. You will need to delete them manually. -
PgcEdit 0.5.4 released!
Changelog:
Zitat0.5.4 (April 21, 2005)
E. New PgcEdit_preview v0.7: with option to turn off the usage of DirectDraw
overlays to show the preview, and an option to save the menu backgrounds
as PPM instead of BMP (internal use only!)
E. Added "Preview -> Disable DirectDraw Overlays" (Windows only) option. On
some systems, it may be faster to turn off the DirectDraw overlay display.
E. Shift-clicking on the "BMP" button in the preview window allow to save an
image in PPM format.
F. Inport First-Play/Intro/Closing Clip macros were broken in 0.5.3. Fixed.0.5.3 (April 20, 2005)
A. Added an option in Info -> Calls Cross References do delete the commands
in the unreferenced PGCs, and to clear the Prev/Next/GoUpPGC links. May
be used to find more unreferenced PGCs in subsequent calls to the Calls
Cross References function. Also, another option allow to convert unref-
erenced menu PGCs to dummies, to easily blank them with VobBlanker.
A. Added "Delete All Commands" in the Edit (and popup) menu.
F. Important bug in v0.5.2 fixed: new buttons created in a cell originally
without buttons/BOVs were saved only in the first nav pack of the cell.
F. PgcEdit was unable to parse the VTSM_C_ADT table if the table was present,
but with no entries defined in the table. Fixed now.
F. Fixed a bug in the parsing of the VTS_C_ADT table, occuring in rare
circumstances: a wrong Nav Pack number was read, causing the search for
menu buttons or BOVs to fail.
F. Inport First-Play/Intro/Closing Clip: The cell commands numbers of the
imported title are now forced to 0 in the cell playback table.
F. Added a little delay when the Open DVD/Save DVD file requester is closed,
to avoid a little Tk bug. -
PgcEdit 0.5.5 released!
Zitat0.5.5 (April 22, 2005)
A. PREVIEW (and menu backgrounds) available for Linux, and probably also for
Mac OSX. You must install wine (for Linux) or darwine (for Mac OSX) to be
able to use it.
A. Added the Preview -> Use Preview option, to allow Linux or Mac users to
turn the preview off, in case of problems with wine or darwine. Although
not verry useful, this option is available also under Windows.
F. Fixed a bug in v0.5.4, which caused the display of 16:9 letterboxed menus
in the menu viewer to fail.
F. When saving menu buttons, if you answered NO at the "Backup VOB?" request,
PgcEdit offered to backup the VOB again and again. Fixed. -
PgcEdit v0.5.6 B1 released
Changelog:
* Added the command "Delete All Commands in PGC" in the PGC Selector popup menu.
* Added the utility "Delete All Commands in Domain", also available in the PGC Selector popup menu.
* Added the function "Delete All Commands in DVD", available only by right-clicking on an empty line in the PGC Selector.
* Added the utility "Blank out all Title PGCs in DVD", that calls the "Blank Out All PGCs in Domain" utility in sequence for all title domains.
* Added an option to change the default colors of the GUI, requested by a Linux user. -
PgcEdit 0.5.6beta6 ist raus.
ZitatPgcEdit: Version history
A. = Added feature
R. = Removed
E. = Enhancement
F. = Fixed bug0.5.6beta6 (May 2, 2005)
A. A wrong path was used to store the configuration files on some Win XP foreign systems. Hopefully fixed now.0.5.6beta5 (May 1, 2005)
A. PGC Editor: Added an edit popup menu on the audio and subpic streams title label to copy and paste all audio or subpic streams assignments.0.5.6beta4 (April 29, 2005)
A. Option "Skip Preview of short cells (< 1sec., without still time)?" in the preview configuration of the trace mode.
E. Jump2Pgc now uses the still unset GPRM with the lower usage count if an unused GPRM cannot be found.0.5.6beta3 (April 29, 2005)
F. Fixes some problems in the new Jump2PGC macro.0.5.6beta2 (April 28, 2005)
A. New semi-automatic macro "Jump to PGC upon DVD insert". It's a modified version of jeanl's "Jumping straight to the movie (or the menu) with PgcEdit" and 2COOL's "Jump2Pgc" guides.
A. Added "Swap or Copy Menu PGC" utility, to swap or copy the PGC parameters (cell table, color table, streams, VM commands,...) from another PGC of the same menu domain with/to the current PGC. Useful to cleanup the menus.
Wie immer hier.Cu Rippraff
So jetzt ist die Final von 0.5.6 raus!
Zitat von r0lZ
[font=verdana, arial, helvetica]PgcEdit 0.5.6 released.
A. = Added feature
F. = Fixed bugA. New semi-automatic macro "Jump to PGC upon DVD insert". It's a modified version of jeanl's "Jumping straight to the movie (or the menu) with PgcEdit" and 2COOL's "Jump2Pgc" guides.
A. Added "Swap or Copy Menu PGC" utility, to swap or copy the PGC parameters (cell table, color table, streams, VM commands, ...) from another PGC of the same menu domain with/to the current PGC. Useful to cleanup the menus.
A. Added the command "Delete All Commands in PGC" in the PGC Selector popup menu.
A. Added the utility "Delete All Commands in Domain", also available in the PGC Selector popup menu.
A. Added the function "Delete All Commands in DVD", available only by right-clicking on an empty line in the PGC Selector.
A. Added the utility "Blank out all Title PGCs in DVD", that calls the "Blank Out All PGCs in Domain" utility in sequence for all title domains.
A. Added an option to change the default colors of the GUI, requested by a Linux user.
A. Added a button "All" in the search GUI, to display all occurences in a window. You may click on the buttons to jump to any occurence.
A. Added some icons for Linux users (included in the Zip archive), thanks to M7S.
F. PgcEdit_Preview 1.8 by jeanl. See history at the bottom of this file.
F. Fixed a little bug in Kill Playback macro that caused the display of an erroneous warning when killing the playback of a menu PGC with some cell commands (LinkTailPGC...)
F. A wrong path was used to store the configuration files on some Win XP foreign systems. Fixed.
F. Fixed a little problem when using an Alt-F# system key under windows: The tool associated with the F# key was launched instead.
F. Fixed a bug in the error message routine when a DVD cannot be opened successfully.
F. Fixed a rare bug in trace mode.
PgcEdit_Preview 1.8 by jeanl:
Fixed a bug in original DVD2AVI code that caused the CELLID to be incorrectly read from the VOB file in some rare instances.
Enabled the original code to avoid an extremely rare problem where DVD2AVI finds a SEQUENCE_HEADER_CODE in the first navpack.
[/font]
Wie immer hier.
Cu Rippraff -
PgcEdit v0.5.7 B2 released
Changelog:
Beta2:
# F. Fixed some english grammar/vocabulary errors.
# F. When the option "Store backup folder in parent of VIDEO_TS folder" is ON, the backup folder is saved now in the parent only if the DVD files are in a VIDEO_TS subdirectory.
# F. Some display problems on Macintosh platforms (default font size...) are now hopefully fixed.Beta1:
# A. Added an option to hide the [hex codes] in the main commands listbox.
# A. Added an option to go automatically to Trace mode whan a DVD is opened.
# E. The "DVD modified, are you sure?" warning now allow to save the DVD.
# F. Fixed a typo: changed all occurences of sheme to scheme. -
PgcEdit 0.5.7 beta 3 released.
http://www.videohelp.com/~r0lZ/pgcedit/versions/?C=M;O=DYet another beta, mainly for Mac users running Tk-Aqua.
* F. Error when blanking a titleset when the preview window is open fixed.
* F. "Save IFOs as" saved the modified VOBs also (in the original folder).
* F. Fixed more display problems under Mac and Tk-Aqua. -
0.5.7 (June 4, 2005)
A. PgcEditor: Added an Angle column ("A.") in the cell list.The angle value is computed from the Type Flags."-" means all angles, "?" means error.
A. Added a function to remove the current LU from the IFO.The VOB cells are left unreferenced.You may strip them with VobBlanker easily.
A. Added a button "CellTimes.txt" in the Pgc Editor to generate the list of cell times needed to remux a clip with chapters.You may add an offset to the cell times if you want.
A. Shift-clicking on a PGC in the PGC Selector now toggles the breakpoints on that PGC (without selecting it).
A. Added a "Documentation" item in the help menu.It tries to open these files: "<PgcEdit install dir>/doc/PgcEdit_manual.chm" (under Windows only) then, if the file is not found, "<install dir>/doc/PgcEdit_manual.htm", then "<install dir>/doc/PgcEdit_manual.txt", and finally, it opens the online HTML version stored at VideoHelp. The old, obsolete single text file has been removed from the distribution.
A. Added an option to tell PgcEdit which web browser you want to use.Now, the homepages, online docs and DVD-Replica online help are available also for Linux and Mac users.
E. The shortcuts of the context menus of the PGC selector are now displayed in the menu.
E. Added tooltips on the edit buttons with the keyboard shortcuts.
E. Added tooltips in PGC Editor's color table to show the color number.
E. Added some tooltips on the labels of the cell list in the PGC Editor.
E. Added the Control-Delete shortcut to call the Blank Out All PGCs utility.
E. New Preview 1.9 by jeanl.In info mode, the buttons outlines are displayed.Also, mfc42.dll is now linked in the executable, and is therefore not needed anymore under Linux.
F. Bug in the Search function in All mode: the line numbers were wrong.
F. Menu Editor: The Align button functions where not working as expected when the current button position was previously edited manually.Fixed.
F. Workaround for a Tk bug under X11 (Mac and Linux): a wrong height is calculated by Tk for windows with menus.Therefore, the OK/Cancel buttons were hidden in the menu editor.
F. Some display problems fixed under Mac (X11 and Aqua versions.)
F. Trace:LinkTopCell in a menu button linked to the previous cell.Fixed.
F. Fixed a rare bug when reading the menu buttons informations.
F. Fixed some english grammar/vocabulary errors. -
PgcEdit 0.6.0beta7 released
Changelog:
A. = Added feature
R. = Removed
E. = Enhancement
F. = Fixed bug
0.6.0beta7 (June 18, 2005)
F. Fixed a bug when compilation size > DVD-9 size.
E. The angle cells are now removed from the list of valid cells for the layer
break.
E. Added two fields in the Burn Setup dialog to type the default size of the
single layer DVDs and the DL DVDs. An "Use" button has also been added.
The top frame of the Burn dialog lists also the DVD and DL-DVD capacities.
The output of the Check DVD+/-R size function has also been modified.
F. Fixed some bugs in the Find All function: the line number (when the target
was a pre, post or cell command) and the cell number (when the target was
a button or BOV) were off by 1, and the button group was not always
correctly displayed. The GUI has been changed also to avoid the Tcl/Tk
limitaiton of the number of occurences that can be displayed in a canvas.
0.6.0beta5 (June 13, 2005)
A. Added button "Seamless cell" in the burn DL-DVD GUI, to clear old layer
break flags.
0.6.0beta4 (June 12, 2005)
A. Added shortcut Control+P to launch the PGC Preview.
F. Fixed a bug in the calculation of the number of padding sectors when the
selected cell's original LBA was < compilation size / 2.
E. Some improvments in the burn DL interface.
0.6.0beta3 (June 10, 2005)
F. Fixed a bug in the calculation of the minimum sector value for the LB.
0.6.0beta2 (June 8, 2005)
R. Removed the original link to DVD Decrypter's homepage in the Burn Setup
dialog because this page is discontinued, and may be monitored by a major
DVD company. Replaced by a direct download link at Doom9.
F. Two big bugs fixed in the Burn DL routine. Should work now!
E. If the option to burn with DVDD is ON, the number of sectors in L0 is set
automatically in the setups of DVD Decrypter, via the registry.
0.6.0beta1 (June 6, 2005)
A. The Burn function (under Windows only) is now able to burn Dual Layer
DVD-9s. Added a GUI to retrieve the Layer Break cell. Note: You MUST
burn the ISO with DVD-Decrypter or a burner that honor the LB placement!
E. Added an option to change the default listbox background color to white
under X11 (Linux, and Mac with Tk-X11).
E. Menu Editor: Changed the menu labels Buttons -> Align vertically and Align
horizontally to Align on same column and Align on same row. -
Hi
wo gibts denn die beta´s ??
finde die nirgends.danke
