ZitatVersion 2.6.2 - 07 Nov 2004
fix: pauses during playback
DVDRemake pro - aktuelle Version
Ich hab mir die neue 3.0 vorgestern gekauft und bin begeistert :ja:
kleiner Tipp über den Referer von MackemX's DVDRemake Page
http://www.deano.dsl.pipex.com/dvdremake/dvdremake.htm
gibt es 10 % Rabatt beim Kauf von DVDRemake 3.0also nur $44.96 :ja:
statt $49.95 -
Und wenn man den Dollarkurs noch bedenkt...
hab mir grad das update um 10$ gekauft, die neuen funktionen sehen vielversprechend aus.
hab mir damals die 2er version um um $31,99 USD gekauft (weihnachtsaktion mit 20% rabatt)
Version 3.0.1 - 30 May 2005
crash previewing disks recorded with some DVD recorders
small GUI fixes (spelling errors)
Ctrl+M shortcut key does not work
modifications to keyboard shortcuts processing (for StickyKeys)
show blocks size in Domain Content pane
unable to use "cut to here" on the remaining angle (after strip angles)
crash deleting chapter pointing to already deleted PGC
"Preview original" dialog title
do not allow SPRM as left operand in conditional part of "Special Insturction" commands
crash if PGC refers to non-existing audio track -
Version 3.0.2 - 16 Jun 2005
- support for multiple selection in PGC Programs pane
- paint background under button # to improve its visibility
- support for multiple selection in VMG titles pane
- selection behaviour with right clicks and multiple selection actions for Commands pane
- command before added is selected after "add command" action
- restrict minimal window size to 640x480
- condition and link can't be used together in "System Set" commands
- use puops not only from first nav-pack
- problem with FF, FR after split cell
- "download user manual", "visit forum" and "download latest version" links in Help menu
- option to turn off info in preview window -
Version 3.0.3 - 17 Jun 2005
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] crash deleting last program in PGC
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] hide info overlay in Preview pane while F6 is pressed
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] hide info overlay in Domain Content pane while F6 is pressed
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] don't set PUOPs for PGC blocks when "Set Prohibited Operations" is done for PGC
Version 3.0.4 - 20 Jun 2005
- problem with selection synchronisation in different PGC view panes introduced in 3.0.2
- "Add Command" shortcut for Commands pane is changed from "Ctrl+A" to "C"
- "Add Title" shortcut for VTS Titles pane is changed from "Ctrl+Shift+T" to "T"
- "Add Chapter" shortcut for VTS Titles pane is changed from "Ctrl+Shift+C" to "C"
- add "Del" shortcut for "Delete Chapter" in VTS Titles pane
- "Add Title(s)" shortcut for VMG Titles pane is changed from "Ctrl+Shift+T" to "T"
- added chapter is not selected after "Add Chapter" in VTS Titles pane
- added title is not selected after "Add title" in VTS Titles pane
- support for multiple selection in PGC Subpicture Tracks, PGC Audio Tracks and Domain Content panes
- "Select All" is added to Commands, VMG Titles, Programs, PGC Subpicture Tracks, PGC Audio Tracks and Domain Content panes (shortcut Ctrl+A) -
Version 3.0.6 - 24 Jun 2005
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] scroll bar in Domain Content pane is not updated after switching to another domain
gibs vielleicht irgendwo noch bissel mehr Prozente als 10%?
schreib dem autor das du weihnachten leider verpasst hast, und trotzdem gerne 20% rabatt hättest
ist vielleicht einen Versuch wert :lol:
Version 3.0.7 - 8 Jul 2005
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] use yellow highlights in default start-up menu for merged disks to improve visibility of selected button
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] select new file location while opening saved project if needed file was not found
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] problems with start-up menu of merged disk when in Auto PS/LB mode
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] scroll bar position in Domain Content pane after editing
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] small GUI bug with playback controls in Preview window on some systems
Version 3.1 - 21 Jul 2005
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - convert cell to still: preview cell to select frame to be used as still, right-click and "convert to still". It keeps audio and subs (can be removed as usual) and original duration of the cell (in most cases).
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - hidden buttons are not automatically "forwarded" to nonhidden button in some cases
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - crash when "don't keep" undo/redo option is selected
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - keep found "skiped blanks position" to avoid searching next time block is shown in Domain Content pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - if SHIFT is hold while copying PGC/VTS (in DvdTree pane) it is added to the clippoard (instead of owervriting what was there); add copied PGC/VTS will add all copied so far items
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - copy/paste blocks in DomainContent pane (supports multiple selection; paste is allowed only when selected blocks amount is the same as amount of previously copied blocks; selected blocks are replaced one-by-one; even multiangle blocks can be replaced this way)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - show edited block size (instead of original) in Domain Content pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - show edited block size (instead of original) in Preview pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - "Convert menus to still" action for Language Unit (menus) in DVD Tree pane: hides menus without buttons, converts menus with buttons (not yet converted) to still
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - "Replace with still" action (can be invoked from Block Preview pane): replaces block video with selected frame
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - edited flag is not set in some places after disabling/editing audio/sub tracks (affects "update export") -
Ich hab mal den oberen Post editiert, so dass man jetzt auch sehen kann, welche Funktionen hinzugekommen sind und welche repariert wurden.
Cu Rippraff
v3.1.1
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] (P) - show adjacent buttons in Buttons pane;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - "lost" buttons (buttons that can't be navigated to) in some cases after
hide/delete button;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - streams info for domain is not modified in some cases when blocks are
replaced;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] (P) - copy/paste video/audio/subs tracks info;
mod (P) - allow all LUs deletion in advanced editing mode;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - info about selected audio stream is not updated in block preview pane in
some cases;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] (P) - set PUOPs and edit color table actions are not reflected in History
pane and can't be undone;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] (P) - mark "goto line" comand pointing to itself as error (such a command
will result in an infinite loop);
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - a delay before buttons appear in menu converted to still in some cases.passt so? :cool: => sehr hübsch!
Edit: Doch nicht ganz, hatte mich schon über das (P) gewundert, das ist das Changelog von beiden Versionen, die mit (P) betreffen nur die Pro-Version. -
v3.1.2
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - search for DVD files in VIDEO_TS subdirectory if import from specified directory fails;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - size of PGC with interleaved blocks is reported incorrectly in Dvd Tree pane;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - SPRM can't be used as left operand in condition;
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - pop-up command editing dialog on "Add Command";
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] - popup menu to enter button # in command editing dialog
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] - error saving project containing blocks replaced with still background in some cases. -
DVDRemake (Pro) v3.1.3 ist raus.
ZitatHere is the list of changes from previous version (items marked with (P) are applicable only to the Pro version):
mod (P) - pop-up command editing dialog on "Insert Command";
add - "hide menu transitions" action for DVD, VMG and VTS items in DvdTree pane;
add - "convert menus to still" action for DVD, VMG and VTS items in DvdTree pane;
mod - change pop-up menus layout for VMG, VTS, PGC items in DvdTree pane for consistency;
add (P) - popup menu to enter button # when editing "Set highlighted button" command;
fix - convert blocks selected in Domain Content pane to still does not do anything.
Cu Rippraff -
Version 3.1.4 pro - 20 Sep 2005
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] select PAL/NTSC format of VTS with start-up menu in merged disk coherent with the rest of the disk
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] LinkTailPgc commands in all commands in start-up menus pool
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] reused cells are counted more then once when PGC size is computed
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] correct destination of "goto" in inserted command if it points to command after inserted
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] importing DVD from folder above VIDEO_TS gives errors
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] modify destination of "goto" when pasting/adding/inserting copied commands
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] editing mode is not preserved between sessions
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] "Delete all PGCs" action to Program Chains item in DVD Tree -
