NuMenu4u - Aktuelle Version
  • Zeul hat Numenu4u 2.0.12 released
    Changelog:
    • Fix: to overflow error during IFO generation after muxman authoring
    • Added an override setting for DIF4U 1.4.0 users. This version of DIF4U passes both one pass and multipass to NuMenu4u, so CCE ALWAYS encoded at one pass. This new setting will override this in the commandline and use the existing encode method as specified in the Encode settings
    • Added a workaround for when the first subpicture stream doesn’t start at 0x20
    • Fix: to the dummy name convention in mxp scripts
    • Added additional script for dummy assets (caused 0.15+ to fail on multiple scripts)
    • Correction to the Link CN command for muxman scripts
    • Alteration to the way the IFO is generated after muxman has run, to stop incorrect sector offsets due to non-existant tables
    • Added a new setting to confirm the Aspect Ratio of the video stream (under Encoder setting). This might be useful to use when the IFO suggests an AR of 4:3 pan-scan, but the video is actually 16:9 (Very little testing – so I appreciate feedback)
    • If avisynth is not installed NuMenu will still proceed but video encoding will be disabled (use original assets only is initiated) – mpucoder request
    • Rewrote the dummy asset script creation for mxp scripts when creating a FULL script
  • Zeul hat Numenu4u 2.0.13 released
    Changelog:
    06/06/06
    • Changed the installer to stop deleting everything
    • Added right click to open up DVD or any VIDEO_TS folder for NuMenu processing
    • Fix: was passing the actual language not the language code into the mxp script (ie English and not en)
    • Fix: Was writing every PGC & PG of every VTS into the muxman script, where only the referenced ones were needed (for a Full script) and various other changes reflecting full muxman scripts.
    • Added a new setting to enable dummying of certain PGCs (this was already part of NuMenu, but I have decided to have it turned on/off). Basically if a PGC has no pre/post command table but has a cell that has no buttons, then you can never leave this PGC (this is used for example with parental control – warning comes up eject disc). This in the past has been removed but I can see where it might be useful to keep this PGC
    • Added a new drop down menu (subpictures). This can be useful when for whatever reason vsrip doesn’t pick up that there should be a highlight associated with a sub. It is still experimental so use it if you’re menu is missing highlight/button info. There are 2 choices – set the highlight to the first sub that has no highlight associated with it (use if there is only 1 sub per cell) or the 2nd choice which is to compare the subpicture timestamps and the highlight timestamps to make an educated guess to which sub the highlight belongs to.
    • All video encoding now takes place together – this enables the vob preview to show ALL the menus being processed
    • Added a new scenarist option for when automate keeps failing. Setting this option over rides automatic control and will pause NuMenu4u while Scenarist is controlled manually. DO NOT CHANGE THE OUTPUT DIRECTORIES IN SCENARIST!!. Whilst Scenarist is compiling there is a small msg box displayed (which can be minimized) which pauses NuMenu4u. When Scenarist completes pressing the correct button in the msg box will restart NuMenu4u for IFO updating & file copying or in the event of a script error will copy the remaining files (if selected) and create the appropriate batch files.
    • All dummy cells (whether automatic or manually selected) are now encoded as stills. This means that if the warning screens were stripped, the delay to the main menu (or intro etc) would now be negligible – it could have been a couple of secs.
    • In Vob preview (VIP users only) you can now choose still menus (eg warnings) to strip aswell as video clips
    • In Vob preview there is now a bitrate calculator built in which seems fairly accurate.
    • Fix: In the very rare circumstances that a cell was reused within the same PGC, but the cell commands or still times were different, then all these cells would have had their attributes set the same
    • Added an option (under encoder setting) to force an attempt to ensure that every still or un-encoded video asset all have the same video attributes per VTS. Each asset is run through revpulldown. This will reduce the speed of NuMenu slightly. I recommend switching this ON
    • Fix: If selecting confirm aspect ratio setting then the parser could have run beyond the end of the file causing an error
    • Fix: Discovered that in a format conversion the new IFO always had incorrect video attributes (MPEG1, 4:3 etc)
    As a sidenote this build and MuxMan 0.15 RC1 seem to work very well (ie Full script creation)
    "Ist es schon Zeit, um Thaddäus den Tag zu vermiesen?"
  • Zeul hat Numenu4u 2.0.14 released VIPs only
    Changelog:
    * Fix: If the path to Quenc has spaces in it would fail
    * Fix: Discovered that NuMenu was still attempting to re-encode video streams diagnosed/manually selected as dummy, or files that didn’t meet the encoding threshold – this could have caused an error
    * Fix: A PGC link to VMG PGC1 would have caused a muxman error
    * For VIP users added 5 new options
    o Replace button command if the button links to a PGC/PG/CELL that has been stripped. If the button is pressed then the cell will repeat
    o Remove button if the button links to a PGC/PG/CELL that has been stripped.
    o NB In some cases, the button linkage cannot be resolved, if the button works by altering the GPRM values and these are not checked in the linked PGC. NuMenu will check the GPRM values in the linked PGC to see if the common ‘if ( GPRM==….), LINKPGCN etc exists, In this case the linked PGC can be resolved so the button can be removed.
    o Added a Scenaid compatability mode J. This will output an appropriate mxp file but won’t actually mux. A future build of Scenaid will use this to create a full mxp file for Muxman that will then re-create the entire DVD
    o Enhanced the asset removal, so you can now choose to automatically remove all video streams that are not menu screens. This is separated into the VMG and VTS area. In the VMG, non-menu screens are normally warnings etc, in the VTS they are normally intros into menu pages or transitions between menu pages
    * Major enhancement for VIP users: When in the VOB preview screen, the buttons for each menu are now shown. Left clicking the button banner (you’ll see), will change the button color outline to green – this button has now been REMOVED -> Left click to reinstate it. Right clicking will make the button outline majenta – this button has now been forced to AUTO ACTION. Right click again to reinstate the FORMER state (active or removed) This can work in conjunction with the above options. If for example you remove a menu, but forget to remove a button that links to that menu, NuMenu will try to fix this for you. Also, when in this screen, there is now a button that will use the original assets instead of re-encoding (perhaps enough material is being removed that re-encoding the remainder is now not necessary)
    * Fix: When checking the 2nd or 3rd sub stream for compliancy (so the subs = substream1), EnableStop wasn’t being set in some cases. This would cause lots of sub errors in scenarist
    * Fix: The cell still time was still being set in Scenarist is an asset had been dummied. It is now set to 0.
    Known Issue: If the 1st substream is set for PAN-SCAN then the button may look slightly misaligned, but it won't affect the useage.
  • Zeul hat Numenu4u 2.0.14d released VIPs only
    Changelog:
    Corrects a couple of bugs that were found by Pike007. Also added a couple of new VIP options regarding autoselect.
    The full changelog now reads:
    27/06/05
    * Fix: A PGC link to VMG PGC1 would have caused a muxman error due to a script error
    * For VIP users added 6 new options
    o Option to automatically load the VMG and/or every VTS on loadup regardless of size
    * Settings are now saved when the ‘start’ button is pressed instead of at the end (in case of failure)
    * Script alteration to reflect the changes made in Muxman 0.15a
    * Option to automatically select ALL assets in a format conversion, regardless of menu size
    P.S.:
    Die 2.0.14er Versionen wenn ich das richtig mitbekommen hab is ne Beta Version wo vieles dazukommt vorallem VIP only sachen und als Beta nochn haufen Bugs hat und wenn das mal Stabel is auch ne Public Version wider rauskommt
  • Zeul hat Numenu4u 2.0.15 released
    Changelog:
    Quick update
    29/06/05
    * Slight alteration to the UpdateMPV routine
    * Slight change to the Muxman routine, to reflect Muxman 0.15a when being used in MULTIPLE script mode.
  • Zeul hat Numenu4u 2.0.16 released
    Changelog:
    • Fix: When there are more than 600 vobs Scenarist would fail, so a check is made for this, but, this VTS was still called in the UpdateMPV routine causing the error reported by wfn1. NB this restriction doesn’t affect VIP users who have Muxman available
    • When the Copy File setting is set to copy all remaining files (for complete DVD folder or ReBuilder use), then the VTS sector information is now updated automatically.
    • Added the ability to resize the VOB preview window (This may correct any directx problems – unsure but worth a try)
    • Fix: Broke a scripting part in the previous release for muxman
    • Noticed a GUI error when manual pausing of Scenarist initiated
    • Added the ability to generate an ISO image. IF the re-authored menu + the original title VOBs are less than 4.3GB then the original title VOBS will be copied over and an ISO created. If DIF4U is in control it will be shut down. This is a VIP option only.
    • Finally added the help menu. There are multiple links to the correct part of the Help menu, through each screen
    • A couple of corrections to the Wizard
    • Fix: On some occasions the entire AVS script would not be written – caused an error in the Preview Window
    • In the Preview Window, the entire size of the DVD is now shown. Altering the menu bitrate here shows the direct effect on the overall size.
  • Zeul hat Numenu4u 2.0.17 released
    Changelog:
    Fix: Thanks to Trahald a bug came to light in the VIDEO_TS.IFO updating
    Fix: A correction to a specific VMI command, that was dropping the conditional argument
    Moved the ‘Use Original Assets’ setting from General Settings to Encoder – Makes more sense
    Please Update to this build to correct the IFO routines
  • Zeul hat Numenu4u 2.0.18 released
    Changelog:
    • Fix: If processing multiple VTS sets, then the Aspect Ratio variable was not cleared between VTS sets; the dummy menu file would have an incorrect Aspect Ratio
    • Fix: If original assets were kept via the VOB Preview screen, then they would still get encoded
    • Fix: When in muxman mode, and analyzing the button command to determine if the command links to a dummied menu, and if the setting specified was ‘Remove Button Link’ then the button analysis always reported false for LinkNextCell, LinkPrevCell, LinkNextPG, LinkPrevPG
    • Correction to the installer – was trying to register the cygwin.dll
    • If using muxman and full script generation then the command JumpSS VTS0 is now reproduced exactly (YOU MUST UPGRADE TO 0.15c)
    • VIP addition : Use of DGDecode (Modified by D3s7 to output LOG also) is now implemented – To satisfy the GPL a weblink to Neuron2’s website has been added (Under Help)
    • Settings are now saved as soon as the ‘Goodbye’ button is pressed. This means you can set up the settings straight away without having to process a menu.
    • Added AutoGopSize to the GOP options. This is now the default. For previously installed versions then this will need to be enabled
    • Updated the copying & sector routines – they would fire even if authoring had failed or was skipped – caused a sector error
    • Altered the Scenaid compatability mode switch slightly – forces a confirmation of this NB THIS MODE IS NOT YET AVAILABLE IN SCENAID so do not ENABLE
    • Fix: In scenarist script file, dummy menu files were being created for non processed menus. The expected file therefore didn’t exist and scenarist would fail with a placeholder error
    • Updated the Donate URL
    • Fix: A source reported as 24fps (not 23.976) would get encoded as 29.97
    • Fix: The correction for conditional argument in VMI command on previous build, actually broke it in scenarist
    • Pressing the ‘Cancel’ button now close Recovery Console aswell as resetting the variables
    • Altered the dialog control for some of the controls
  • Zeul hat Numenu4u 2.0.19 released
    Changelog:
    19/07/07
    • Added option to remove temporary files on completion (except NuMenu4u.log)
    • Fix: Unable to set the path to SoftEncode
    • If a VOB is reused across different Language Units , and each LU uses a different substream, NuMenu will now no longer crash, and the scripts have the correct id’s flagged.
    • In Default settings screen, now have the option to permanently set the start up drive or folder / destination drive or folder / actual working directory name.
  • Neue Version:
    2.0.20
    Changelog:
    10/08/05
    • Fix: SoftEncode path this time!
    • Fix: Incorrect ecl settings could have arisen due to only part of the AVS script being written (this corrects wmansir’s error)
    • Fix: Forward slash was missing from the source path in the Rebuilder.ini file. The source would not be loaded on opening. Also changed Rebuilder to open normally and not minimized.
    • Noticed that when using PGCDemux for a folder demux, cell demuxing wasn’t working correctly
    • Added a better error handler if no LOG file is produced from DVD2AVI / DGIndex
    • Fix: Found a bug when writing the PGC type in unprocessed VTS’s. If multiple LUs then Root Menu could be written more than once per LU
    • Further alterations to way the substreams are handled. This time to correct any streams that are not used but exist in the VOB file
    • Added a sanity check for Format Conversion, encoder issues and authoring issues.
    • Added multiple language support for the GUI. Pre installed .lang files are English, Italian, German & Dutch. If others are created, they will automatically be found in the install folder. Use the Pre installed ones as a template. (Many thanks to Influenza, TuRiSOft, FreaQ)
    • Removed the necessity for a progress bar ocx , fixes a particular issue with XP
    • Added HC Encoder support – The latest build with chapter support MUST be used – All internal matrices/profile can be used
    • Also added the ability to set a custom matrix for HC Encoder
    • Added the ability to use the original matrix of the asset with HC Encoder. The original matrix is determined by analyzing the video segment with QuantDump.
    • The Eject after Read setting for DVD Decrypter is now automatically corrected to = 0 before NuMenu processing is started. If the setting = 1 before, then the setting will be restored on closure. This is to stop the iso from being dismounted before processing has finished.
    • Altered the recovery console slightly – makes it easier to use
    • Added an encoding check after CCE has finished. If for some reason CCE failed, encoding will be restarted for just those assets that failed. NB this will not pick up an encode failure that results in only part of the video. If after 4 attempts some assets are still missing then the originals will be used for the missing ones. NB if doing a conversion from PAL -> NTSC this is not possible, so NuMenu will abort
  • Zeul hat Numenu4u 2.0.21 released
    Changelog:
    • Fix: Pulldown wasn’t being called after HC encodes (if needed).
    • Fix: closing the recovery console would disable the ‘X’ in the main form.
    • Fix: if numenu was minimized to the system tray from dif4u, and then restored a stack error would arise
    • Added the LOGFILE parameter to the HC ini file, so that any issues will be recorded.
    PS:
    HC Encoder 0.15A hat z.Z. einen bug der einen sofortigen crash verursacht.
    Nicht verwenden bevor Hank315 das Problem nicht behoben hat.
  • Habe mal die deutsche Sprachdatei überarbeitet.
    Rechtschreibfehler beseitigt und sonst noch ein paar Kleinigkeiten.
    Wenn es sonst noch Verbesserungsvorschläge gibt, nehme ich diese gerne an.
  • Fürs erste: Spitze!! :daumen:
    Firma dankt.
    Achso. Hast du an die Möglichkeit gedacht das Teil dann auch an "ZEUL" zu schicken? Könnte man ja ins englsiche Forum setzen..
  • An Zeul hab ich es schon geschickt. Ins englische Forum habe ich es nicht gesetzt. Wäre evtl. eine Überlegung wert.
    Funktionieren die Sprachdateien eigentlich auch ohne VIP?
    PS: Die mitgelieferte Version in NuMenu stammt auch von mir.
