Zeul hat Numenu4u 2.0.12 released
Changelog:
• Fix: to overflow error during IFO generation after muxman authoring
• Added an override setting for DIF4U 1.4.0 users. This version of DIF4U passes both one pass and multipass to NuMenu4u, so CCE ALWAYS encoded at one pass. This new setting will override this in the commandline and use the existing encode method as specified in the Encode settings
• Added a workaround for when the first subpicture stream doesn’t start at 0x20
• Fix: to the dummy name convention in mxp scripts
• Added additional script for dummy assets (caused 0.15+ to fail on multiple scripts)
• Correction to the Link CN command for muxman scripts
• Alteration to the way the IFO is generated after muxman has run, to stop incorrect sector offsets due to non-existant tables
• Added a new setting to confirm the Aspect Ratio of the video stream (under Encoder setting). This might be useful to use when the IFO suggests an AR of 4:3 pan-scan, but the video is actually 16:9 (Very little testing – so I appreciate feedback)
• If avisynth is not installed NuMenu will still proceed but video encoding will be disabled (use original assets only is initiated) – mpucoder request
• Rewrote the dummy asset script creation for mxp scripts when creating a FULL script
