http://www.miranda-im.org/
http://www.heise.de/newsticker/meldung/58371
Zitat von ChangelogAlles anzeigenBugfixes:
- Crashes after warning about unsuccessful search
- ESC doesn't work in User Detail
- Phrases with leading and trailing spaces not translateable
- Incorrect Local time in Userinfo
- CheckDlgButton didn't draw correctly if used after creation in button control
- Offline users weren't always shown in Typing Notify Options
- Ctrl+w closes message window
- Moving a group outside the CLC causes a crash
- Crash translating a menu
- Scrollbar still appeared sometimes if XP skinning was enabled
- Contact list control read-disk-on-paint bugs
- Many database bug fixes (crashes, corruption)
- Crash opening Find/Add dialog
- No & sign in the Open File button on the File Transfer window
- Visual defect in "Options\Contact List\Icons" when Expert options unchecked
- AIM: Removing user from deny list didn't always update mode in Miranda
- AIM: Fixed file transfers with Mac users
- ICQ: Error alert blocked I/O
- ICQ: Newly added contact with privacy setting is not hidden anymore
- ICQ: Offline messages are no longer received older than existing ones
- ICQ: Fixed authorisation reply
- ICQ: Fixed contact transfer ack
- ICQ: Now parses URL send ack correctly, no more timeout
- ICQ: Now sending ack on contacts receive
- ICQ: Fixed crash on receiving long message through P2P
- MSN: Connection/login fixes
- IRC: Many bug fixes
- Yahoo: Much cleaner/better/stable codeEnhancements:
- Database and contact list control moved to plugins
- Relative paths for icons, sounds, and contact list background
- Scroll through past messages with ctrl+up/dn in message window
- New idle module to handle autoaway and protocol idleness
- Pin to desktop option in Window options
- Dim idle contacts option
- Use windows colours option for contact list
- New status bar options (hide bevel, hide gripper)
- Database I/O improvements
- Option to hide vertical scroll bar
- Opening a URL blocked I/O
- AIM: Show mobile users as 'on the phone'
- MSN: Sending/receiving avatar support
- MSN: Peer to peer support
- ICQ: Added avatar tab to user-details dialog to show avatar
- ICQ: My user-details now show more information & added idle since to ICQ tab
- ICQ: Added full unicode message support (requires SRMM Unicode)
- ICQ: Added support for sending and receiving Idle time
- ICQ: Added reliable client identification
- ICQ: Added support for avatar images (downloading & uploading).
- ICQ: Added Grant authorisation option (send & recognize)
- IRC: Support for secured connections using OpenSSL
- IRC: Support for CTCP and DCC filetransfers and chats
- IRC: New graphical user interface using Chat plugin
- Jabber: Unicode support
- Yahoo: Better Unicode support
- Yahoo: New Buddy Search
- Yahoo: File Transfer support
- Yahoo: Stealth support (Yahoo v6 visibility list)
- Yahoo: Idle support
- Yahoo: Avatar support (retrieval only)
Miranda IM ist ein Messengerprogramm, das viele Protokolle kennt (MSN, ICQ, IRC, Jabber...) und sich durch jede Menge Plugins erweitern lässt.
