staxrip x64
Multiformat video encoding application.
Features
- Handles common input formats and allows to config how files are loaded and processed
- x264, x265, VP9 and XVID encoding
- AMD VCE H.264 encoding
- Intel Quick Sync H.264/H.265/MPEG-2 encoding
- NVIDIA H.264/H.265 encoding
- Output Formats: AVI, MP4, MKV, WEBM
- Output Codecs: XVID, H.264, H.265, VP9, MP3, AC3, AAC, VORBIS, DTS, FLAC, OPUS
- Batch Processing including support for processing sub-directories recursively
- Flexible AviSynth and VapourSynth editor
- Video comparison tool to compare codec and filter options
- Minimal user interaction required due to ´flexible configuration and automation features
- copy modes for audio and video for plain remuxing
- Cut/Trim/Edit feature
- Macros can be used in scrips and command lines allowing to change settings at any time
- Scripable with C# and PowerShell scripts
- External AviSynth filters and command line tools can be integrated
- Project, project template and profiles support
- Job processing
Requirements
* .NET 4.6.1
* Intel Skylake CPU for HEVC/H.265 hardware encoding
* NVIDIA Maxwell gen2 card for HEVC/H.265 hardware encoding
* Java for ProjectX in case MPEG-2 files are opened
* AviSynth+ x64, the installer is bundled with StaxRip x64
* VapourSynth x64 as optional AviSynth+ alternative
* Python x64 in case VapourSynth x64 is used
Documentation
https://stax76.gitbooks.io/staxrip-handbook/content/
Download
