Changes:
New: CloneCD found a new home at SlySoft
New: Can now emulate SafeDisc 2.9 weak sectors!
New: Improved weak sector emulation!
New: Shiny Look under Windows XP
New: "Hide CDR Media" no longer needs to be disabled while using CloneCD
New: added support for more CD-Writers
New: New Online Keys
New: Added RegCloneCD.exe for new keycodes
Removed "Virtual CloneDrive" from Distribution, will be a separate download (or you can just use Daemon Tools)
Removed ControlElbyCDIO from distribution
Removed ElbyCrypt.dll
Removed ElbyCheck.exe
Removed support of CloneCD 2.x keycodes
Removed "Send E-Mail about a Device" function
Removed Microsoft HTML-Help
Removed input window for old keycodes
Fix: CloneCD Tray no longer interferes with Windows XP Task Bar
Fix: Hanging context help
Important Fix: ElbyCDIO reworked, many bugs fixed
Important Fix: Fixed problems with VIA IDE Busmaster drivers
find it here: CloneCD-Version 4.3.1.5
