http://www.mediachance.com/files/dvd-labpro155.zip
- Group assets by Parent Folder option, with the ability to drag the whole group to the connection which will create multiple movie objects.
- Customizable Test Compile (you can specify which Movies are going to be replaced by Dummy)
- A new Link HUB object, a single place that distributes links across the project optionally with setting two GPRM parameters. Great for training, quiz etc.
- fix: Labtalk VM commands and the Block/Script confussion
- added Open & Free memory - open large project while freeing menu memory on the same time
- Record module enhancements and drivers compatibility issues (v. 3.1)
