Help ! lol
i started ripping years ago, stopped then and now started again.
Years ago i did sbc stuff, nandub and co, but did not have the time yet to work it out again, forgot most shit. using gordianknot know. its fine tool, but i got a funny problem...
its some dvd with complete season of a famous animated series! ;D
let me start explaining SOME problems i have with this .. and there are a couple.
First, doing the dvd2avi part - source is interlaced - there are episodes ( from the SAME dvd ) for which "swap field" helps, but for most of them it doesnt. so in most cases i dont select it ( just for one i did, where else i never got a working divx, either it was unsharp or it was 10mb to small then i wanted ).
Second problem is more ugly, there are two ways i have to encode the episodes ( i have to try always, there isnt one that works for all ).
Either i select "neutral bicubic" in combination with "seperate fields - fast" -> about 2/3 of episodes work with this, but with some bad pixels/frames i will show you after this text.
The other option is to take "neutral bicubic" with "field deinterlace" with this option 1/3 work fine, even NO problem with bad frames, at least i did not found any lol, but 2/3 are unsharp - so i cant use this method.
The Problem is -> http://www.devastation.de/dreami/fuck.JPG
Most Episodes have this problem, some more, some less.
during the episode itself, i did not find any bad frames like this, looked hard, but its not that easy to find.
i tried everything, nothing works, the only way to get rid of this is unsing anti-shit - but this is DAMN slow. so i thought, why not ask for help here. maybe anyone can help.
my old account is gone so i registered new one!
help is much appreciated, excuse my not too good english, i was a lazy school boy. lol!
good nite
----------------------------- german version ------------------------
Lol, naja danke fürs drauf aufmerksam-machen!
Habe vor ca. 3 Jahren mitm encoden begonnen - damals noch mit nandub/sbc- dann aufgehört für ne lange Zeit und nun wieder begonnen - diesmal aber mit gordian knot!. Allerdings mit ner ziemlich harten nuss, es handelt sich hierbei um 2 komplette staffeln einer sehr beliebten animated serie ... *g*
Drei Probleme dürfte ich im Laufe der zeit kennenlernen, und da ich weiß dass viele hier richig was aufm kasten haben dachte ich, fragen kostet nix!
Also zum ersten Problem :
Beim dvd2avi part - die bildsource is interlaced gibts ein paar episoden - allerdings sehr weniger - bei denen die option "swap field" etwas nützt, bei den meisten jedoch gibts keinen unterschied zwischen "none", "swap" und der dritten option, bin zu faul nachzugucken wie genau die heißt. deshalb lass ichs hier immer auf none stehn, nur einmal hab ich swap field auch wirklich genutzt, weil anders IMMER fehler auftraten, welche genau kommt unten dran
Mein 2. problem ist deutlich härter bzw ekliger....
Es gibt kein "allround" verfahren mit dem ich alle eps encoden könnte, entweder nehme ich "neutral bicubic" in kombi mit "seperate fields - fast" -> mit dieser option erziele ich recht ordentliche ergebnisse, allerdings - wie unten aufm bild zu sehn, pixelfehler - lustigerweise nur zu beginn also beim intro der jeweiligen eps ( jedenfallss hab ich später keine gefunden
Als Alternative muss ich für manche eps "neutral bicubic" mit "field deinterlace" nutzen, 1/3 klappt damit einwandfrei, auch keine pixelfehler, die anderen 2/3 sind aber unscharf wie nichts, unschaubar.
Hier der screen -> http://www.devastation.de/dreami/fuck.JPG
Diese Pixelfehler treten sowie ich das sehn kann NUR zu beginn auf, fast bei jeder eps beim gleichen buchstaben "R", innerhalb der eps hab ich nix sehn können, ist allerdings auch schwerer zu erkennen als zu beginn.
ich hab jede combi ausprobiert, aus resize filtern und deinterlacing, nix davon hat die pixel-fehler weggekriegt, entweder - wie oben gesagt - unscharf oder halt bildfehler. Mit Anti-shit gehts zwar, allerdings ist das encoden damit unglaublich lahm, deshalb hoffe ich, dass vlt jemand mal ein ähnliches problem hatte und mir deshalb helfen kann!
ich bedank mich schonmal im voraus, schlaft gut
