Hallo Jungs,
ich habe mal einen kleinen DVD Multiplex Test gemacht. Und war dabei SEHR Erschrocken.
Bitte vergleicht mal Time, fps und die Frames
Original
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
Mutiplex Test mit 2 Audiospuren (PCM und AC3)
DVD Maestro
IfoEdit 0.95 / 0.96
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:06:17.07 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Red]00:06:17.07[/COLOR][/B] / [B][COLOR=Green]25 fps[/COLOR][/B] [Pos: 00:06:17.07] [Frames: [B][COLOR=Red]9432[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
dvdauthor (v 0.6.8 , mplex-2 kann kein LPCM2 deshalb Original VOB übergeben)
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: Not Specified (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: Not Specified (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 30 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16[/COLOR][/B] / [B][COLOR=Red]30 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Red]5656[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
Mutiplex Test mit einer Audiospure (AC3 Audio Only)
IfoEdit 0.96
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:06:17.07 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Red]00:06:17.07[/COLOR][/B] / [B][COLOR=Green]25 fps[/COLOR][/B] [Pos: 00:06:17.07] [Frames: [B][COLOR=Red]9432[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
DVDLab 1.3x
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
ReJig 0.5c
Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (pan-scan & letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
dvdauthor (0.6.8, mplex-2 2.0.0)
Ergebniss
++++ DVD Maestro : mehrere Audiospuren, Time=ok, fps=ok, Frames=ok
-+++ ReJig : versteht kein PCM, Time=ok, fps=ok, Frames=ok
-+++ DVDLab : nur eine Audiospur, Time=ok, fps=ok, Frames=ok
+-+- IfoEdit : mehrere Audiospuren, Time=falsch, fps=ok, Frames=falsch
++-- dvdauthor : mehrere Audiospuren, Time=ok, fps=falsch, Frames=falsch
Fazit
für mich kommt NUR noch DVD Maestro in Frage, auch wenn es nur kleine Sachen sind.
Und über IfoEdit bin ich SEHR verwundert, das er so viel falsch macht.
Bitte testet es selber mal. Und schreibt Eure Erfahrungen !!!
