[v0.63a]
- Disabled runt VOBU code for more testing. It appears to have caused more problems then it solved.
[v0.63a]
Version 0.64
- Added support for DGDECODE.DLL. This is a newer, more accurate, and faster version of MPEG3DEC3DG.DLL. In order to use it, download DGMPGDec from the Doom9 site (the only required portion of the .ZIP file is DGDECODE.DLL. You must point to the file from DVD-RB's "Setup" dialog. The MPEG2DEC3 path area name has been changed to "DECODER". NOTE: In order to use DGDECODE.DLL you MUST point to it in the DECODER area of the setup dialog and it must not be renamed (from DGDECODE.DLL). DVD-RB will default to MPEG2DEC3DG.DLL. Hats off to Neuron2 (Donald Graft) who is an MPEG Maestro.
- Removed the "Add to AVS" checkbox from the setup screen. It was a source of confusion and probably should never have been implemented. If you enter a path in the "Path to Decoder" box -- it will be loaded in every AVS file.
- Created a new option under the "Mode" menu that allows you to use a different "Output" path. When selected, the output of VIDEO_TS and AUDIO_TS folders will be sent to that path rather than the "Working Path." This allows users who are low on drive space and have more than one drive to write to two different areas. It also cleans the output up a little -- reducing confusion as to which directories should be burned. You burn only what is in the output directory. If may also increase the rebuild speed. If the option is deselected, DVD-RB will work as it always has -- writing all output to the "Working Path."
- Fixed an error in "Batch" mode in which some parameters from the saved .RDB file were being loaded and set incorrectly.
- Note: It continues to be my intention to provide this package as freeware. But it is my belief that I should somehow reward those to took the time and effort to contribute to this project, either through donation or extraordinary testing support. In the future all new releases will be made to a list of VIPs/donators first. After some period (maybe 30 days) that version will be released in a "public" version. Those who helped through donations and special beta support deserve recognition. This is my way of saying "Thanks." THE FIRST DONATOR RELEASE (IN A COUPLE OF DAYS) WILL SUPPORT MULTIPLE ANGLES AND ILVU (I've completed it and am testing it now).
Version 064.a
[v0.64a]
- Fixed an error in which the "Transcode" button disappeared when selecting/deselecting the alternate output directory while in one-click mode. Silly mistake.
Version 0.66
Below is a summary of the changes/updates associated with this version (VIP release until 30 Nov):
- Corrected an error in which ReJig encoding failed during the "PREPARE" stage when working on a disc with ILVU and/or angles.
- Corrected an error that incorrectly always set the "Aspect_Ratio=" variable in the .D2V file to 16:9. (No impact noted in previous version).
- Found and fixed an error in which interleaved sources, under certain conditions could redirect the PREPARE and/or ENCODE date an incorrect directory.
- Fixed an error in which Subtitles having an number higher than 9 would be incorrectly shown out of order in the "Subtitles to Keep" listbox.
- Added support for "Skins" -- user programmable definition files can be created that load backgrounds, set text, and allow you to customize the way you want DVD-RB to look. NOTE: When DVD-RB is executed it will automatically create a SKINS directory within it's execution path! Several default files will then be created in that directory... these files define the default skins. Two defaults are provide. "Rockas Original" is the interface you've seen, as it was released in version 0.65. Also provide as a default is "Windows Standard" which is very similar to what you would have seen in version 0.64a. You can modify them, customize them, do whatever you want... but remember if you ever run into problems you can always delete the files -- and DVD-RB will recreate them the next time it is executed. You can use the two default skins as a baseline for new ones you create. Simply copy the files, rename, and modify and you can play to your heart's content. The name you use (e.g. "My Skin.txt") when creating a new file, will be added to the "Skins" menu the next time DVD-RB is executed. The SKIN code is new -- so some beta problems and feedback is expected. Enjoy.
Version 0.66a
- Fixed the Rebuilder form's header -- removed "3" from the title
- Fixed an error in which the Subtitles listbox wasn't visible and could not be accessed.
Public release of 0.66a
Version 0.67
- Corrected an error that cause QuEnc to fail due to a "blank" .AVS filename.
- Tweaked SCR calculations to more closely control STD Buffer size. This may reduce or eliminate reported audio dropouts on some players.
- Added "Rewrite Defaults" option to the "Skins" menu. This will recreate the two standard interfaces in the Skins directory. The option is meant to provide a way to correct any mistakes created in editing the files. It can also be used to implement changes I may make to the standard interfaces.
- Fixed an cosmetic error in which some residual color was included in "Folder" buttons.
- Added control over placement of the AudioList, SubList, DTSCheckbox, and MinCheckBox objects in the SETUP dialog box. These were inadvertently left out of the last version.
- To enable the last two fixes -- YOU MUST SELECT "Rewrite Defaults" in the "Skins" menu so the lastest definitions are updated.
VIP v0.68 ist raus:
ZitatAlles anzeigenChanges in this version:
- Fixed an error in which the ReJig pathbox in the Setup Dialog could not be
positioned properly in the Skin definition file.
- Added "ProcoderTargetSectors=" option to the REBUILDER.INI file.
- Changed the maximum frame count accepted per GOP during scanning to a
ridiculously high number. While the DVD spec has a maximum of 18, at least one DVD was encountered that had a GOP of 47. This could be bad authoring, or an attempt to prevent backup. Either way -- it's gone now.
- Fixed an error in which the .D2V file associated with DGDECODE was incorrectly listing PAL resolution as 720x480 (rather than 720x576). This appears to be purely cosmetic, as the statement appears to have had no negative impact.
- Further tweaked SCR calculations. Based upon beta tester inputs it appears the changes in v0.67 fixed most but not all audio dropouts. This fix adjusts the buffer algorithm further in the "less likely to overflow" direction in an attempt to possibly eliminate these glitches.
- Added a new item "Set Background Color" to the "Options" menu. This option will allow you to set and change the color of the background on the "Windows Standard" skin (or any other skin that doesn't include a graphic background). Please note that graphically oriented skins have fixed colors that will cannot be changed by this option.
- Changed the way in which the ILVU_EXTRACT= parameter works. This is in
preparation for some newer methods of handling multiple angles and ILVU sequences that are large.
.... und 0.67 open for public
DVD Rebuilder - New [font=verdana, arial, helvetica]VIP [/font]release (0.69b)
ZitatAlles anzeigen- Modified the "working" directory selection algorithm so that when the "output" directory is not enabled it will be automatically updated to match that selected as "working"
- Inserted code making any segment of 60 frames or less that is being encoded using Half-D1 outputs in CBR mode. This should eliminate the annoying "cce_encoding_init() failed" error that sometimes occurs.
- Fixed the alignment error experienced in 0.68 on the setup screen when used with skins.
- Modified the default skin used under "Rockas Original" -- Rockas has updated this skin with a little less brilliant colors and a nice textured finish. You will need to select "Rewrite Defaults" under the "Skins" menu for the new skin to take effect.
- Further tweaked SCR calculations. This fix again adjusts the buffer algorithm further in the "less likely to overflow" direction.
- Added capability so that audio selections are now saved in the rebuilder.ini file in a manner similar to that used in project files. This makes it no longer necessary to reset your audio choices any time you stop and then restart DVD-RB.
DVD-RB 0.69 PR ist verfügbar
Changes siehe hier
Der DVD-ReBuilder 0.71 VIP ist raus.
- Added support for CCE v2.70. This version of the encoder seems to
have improved quality while also increasing speed. A new CCE option
has been added to the "Options" menu called "CCE SP Trial" -- which
must be used when using trial versions (now that they can accept .ECL
files directly). "CCE SP Trial" uses the path specified for CCE SP.- Added an INI variable through which the header for "CCE SP Trial" .ECL
files can be modified. The variable is called "CCE_Trial_Header" and
it is located in the "Options" area of "REBUILDER.INI" (used for hacks).
Default value is "; CCE SP Trial Version -- Encoder Control List".- The "AudioDub(Blankclip())" is not applicable to QuEncode now. The
setting is ignored when QUENC is selected.- Fixed an issue with the progress bar in which it was not reset properly
when changing skins during encoding.- Fixed an error in which the Batch Abort button could still disappear
when using certain skins (e.g. Simple Blue). Also fixed missing "OK"
buttons in "Simple Blue" skin.- A final minor adjustment was made to SCR calculation to ensure standard
buffer limits are maintained.
die geschwindigkeit von 2.7x scheint in der tat höher auszufallen als bei den vorgängerversionen
ich habe grade einen test laufen und muss nachher nochmal mit 2.67 gegentesten, aber auf den ersten blick scheint sich grad in dieser hinsicht etwas getan zu haben
Zitatdie geschwindigkeit von 2.7x scheint in der tat höher auszufallen als bei den vorgängerversionen
Das kann ich bestätigen, die Geschwindigkeit ist tatsächlich höher.
Um wieviel muß ich auch erst ausprobieren, hab zur Zeit 4:3 Material in mache und da das bei mir seltener vor kommt hab ich da aus dem Stand keine Vergleichswerte.
und die 0.70PR gibts damit auch für jeden.
Zitatund die 0.70PR gibts damit auch für jeden.
also auf doom9 ist noch immer auf 0.69PR verlinkt ?
Zitat von gruaalso auf doom9 ist noch immer auf 0.69PR verlinkt ?
das stimmt so nicht im Forum is es noch nicht richtig verlinkt. Aber hier schon klick
oder dann eben
nach problemen mit cce 2.50 kommt hier nun version 0.72
ZitatAlles anzeigenJanuary 17th, 2005 (v0.72)
- Fixed an error that causes CCE SP V2.50 to create an incorrectly formatted
.ECL file and fail in the encoding phase under certain circumstances.
- The GOP size for NTSC material that is not from a FILM source has been
changed to default to 15 frames (rather than 12). This should improve
quality at a given bitrate on NTSC sources that are interlaced and should
be especially useful on episodic discs of television shows.
- Made a correction to the quality prec value for CCE v2.70. The scale has
been changed (again) in this CCE version. The scale is again set to 0-100.
- Updated the SETUP and ABOUT screens with new images provided by Rockas. Now
there is more room available for viewing paths in the "Rockas Original"
SETUP screen. You must select "Rewrite Defaults" under the SKINS menu for
this change to take effect.
Wobei das neue "Rockas Original" nicht so der Brüller ist.
Das Status-Fenster ist jetzt so schmal, dass man den Text nicht mehr ganz lesen kann. :nein:
Cu Rippraff
