Demux a PGCin elementary streams
ZitatAlles anzeigen
Vers 1.1.0.1 (01-11-2004)
- Added: Multiangle support
- Added: Menu support
- Added: Logfile creation (including audio/video delays)
- Added: Celltimes.txt creation
- Added: Tooltips
- BugFix: Bug in subpictures timestamp calculation (in second and
sucesive discontinuities)
- BugFix: Bug in subpictures extraction when buffer[0x16]!=0
Vers 1.1.0.2 (02-11-2004)
- New build with no changes but with version information OK
All the code was in 1.1.0.1. It was only a cosmetic mistake, sorry for the inconveniences
Vers 1.1.0.3 (08-11-2004)
- Added: Shell integration: "Open with" and "drag & drop"
- Change: Change of file extensions to wav (pcm) and mpa (mpeg)
- BugFix: Error when loading IFOs without menus.
- BugFix: Padding packs were not processed.
- BugFix: LPCM audios extraction were not correct.
- BugFix: MPEG audios extraction were not correct.
Note: I'm still unsure on LPCM extraction, mainly because I do not own
DVDs with LPCM audios (I only was able to test a 16 bit 2 channels one). Also, I didn't find a MPEG2 audio, I only test with a mpeg1 layer 2
