DGMPGDec von Donald Graft - aktuelle Version
  • DGMPEGDec 1.2.0RC1
  • DGMPEGDec 1.2.0RC2
    DGMPGDecVersion 1.2.0 Functional Changes
    (versus DGMPGDec 1.1.0)
    1. Added demuxing of AAC audio from transport streams.
    2. Added preliminary support for PVA streams.
    3. Fixed crash with long GOPs.
    4. Fixed error tolerance on stream video errors.
    5. Fixed problem with indexing for some selection operations.
    6. Further improvements to the Info dialog.
    7. Fixed DGIndex delay calculation for selections.
    8. Revised "info" parameter as follows:
    0: Do not generate debug information
    1: Overlay debug information on the video
    2: Output debug information via OutputDebugString() (Use DebugView utility)
    3: Output hints in the video (as defined in http://utilities.cpp/utilities.h)
    Current hints are progressive/interlaced and colorimetry.
    9. D2V file revised to version 7 format. It now carries more per GOP and
    per frame data. Refer to the D2V file format document for details.
    10. Fixed a problem that caused field structure clips to fail randomly
    (sometimes they worked and sometimes they didn't).
    11. Fixed lots of bugs in the Info display and made it correct for
    random navigation (key data is indexed in the D2V file now, so DGDecode
    doesn't have to try to figure it out).
    12. Fixed bug in the de-ringing postprocessing.
    [Donald Graft, February 6, 2005]
  • [font=verdana, arial, helvetica]DGMPGDec 1.2.0 Final[/font]
    The only changes from RC5 are: 1) Fixed crashing problem in BlindPP() with YUY2 data. 2) Allowed DGIndex to report any audio delay, no matter how wild it seems to be.
    Right after the release is when the big bug is usually discovered. I'm waiting, please disappoint me.[/font]
    http://forum.doom9.org/showthread.php?threadid=90177
    http://neuron2.net/fixd2v/decodefix.html
    ...cu rasta21 :rock: :mosh:
  • [font=verdana,arial,helvetica]DGMPGDec 1.2.1 Beta 2
    [/font][font=verdana, arial, helvetica] 1. Fixed crashing bug in BlindPP().
    2. Fixed incorrect DGDecode postprocessing for YUY2.
    3. Changed DGDecode to deliver YV12 by default. For I420, use
    DGDecode(...,i420=true). This fixes interoperability with some
    applications, such as mencoder.
    4. Fixed erroneous audio delays for multiple tracks.
    5. Added i420 parameter to DGDecode help file, and added an Appendix
    on BlindPP() usage.[/font][font=verdana,arial,helvetica]
    [/font]
  • DGMPEGDec 1.2.1
  • [font=verdana,arial,helvetica]DGIndex 1.3.0 beta 1 -- adds video demuxing[/font]
    http://forum.doom9.org/showthread.php?s=&threadid=90694
    [font=verdana, arial, helvetica]http://neuron2.net/dgmpgdec/DGIndex130b1.zip[/font]
    Benjamin Franklin (1706-1790)
  • DGIndex 1.3.0 beta 4
    [font=verdana, arial, helvetica] This is a bug fix release:
    1. The file list buffer was expanded to prevent crashes when many files are opened at once.
    2. ESC now exits CLI mode.
    3. The delay when doing Save Project on a transport stream without PAT/PMT has been decreased.
    4. AVS template processing with CLI no longer crashes.[/font]
  • [font=verdana,arial,helvetica]DGIndex 1.3.0 beta 5[/font]
    OK guys, here's the prime-time video demuxing. It will start saving at the first sequence header for maximum compatibility with other applications. That means if you have stray frames at the beginning before the first sequence header, you'll lose them, which will affect audio sync. Valid M2V files need to have a sequence header before any pictures.
    The output file is in the same directory as the input files and takes the name of the first file but with extension changed to "m2v".
    http://neuron2.net/dgmpgdec/dgmpgdec130b5.zip
     [/font]
  • DGMPGDec 1.3.1 beta4 ist raus.
    Gibt's hier.
    Cu Rippraff
    Blumige Grüße, Rippraff
  • Schon wieder was neues, DGMPGDec 1.3.1 beta5 ist raus.
    Zitat von neuron2
    [font=verdana, arial, helvetica]This beta adds a fully correct fix for the pitch=width assumption, thereby allowing correct operation under the current Avisynth 2.5.6 beta, as well as the stable 2.5.5 version. Our friend tritical kindly developed and contributed this code revision. Thank you, tritical!
    I added a fix for the emulated header problem by properly parsing the pack layer or transport layer if needed when getting the initial sequence header.
    I also corrected an error in the D2V file format document.
    Please beat up on this hard because the changes are extensive. Thank you.
    [/font]
    Link s. oben.
    Cu Rippraff
  • DGMPGDec 1.3.1 beta 7
