Matroska open source A/V container format officially release
    i have the big pleasure to officially announce that the matroska multimedia container project has finally left alpha status and turned into public beta status last night. By following the links below you will be able to obtain various tools to create, edit and play matroska audio and video files on your computers. Supported Operating Systems are currently Windows and Linux, but it seems at least playback is working for Mac OSX and OpenBeOS also.
    The beta release of these tools is the last and maybe most important of the three initial steps to make matroska a living reality in the opensource community. After almost 18 months of development, always in contact with developers from various other opensource projects in the multimedia environment, we were able to come up with a working specification for the container end of 2002. From this spec our chief developer and project administrator, Steve 'robux4' Lhomme, could code a working basic I/O library called libmatroska, which was released in alpha version to interested OSS developers beginning of this year. Since then all efforts were undertaken to make file creation and playback possible, and in the meantime the main library was steadily developed further to its actual status.
    The matroska container is mainly aiming to replace the good old AVI , but it is also ment to be a powerful and open alternative to other, mainly proprietary, containers such as ASF, MP4, MOV, RM, MPX and even MPEG. It uses the extensions .mkv for video and .mka for audio only files .
    Here the main features of matroska :
    - opensource, open standard, GPL and QPL licensed main library
    - supports arbitrary file sizes, ideal for PCM audio and prepared for HDTV
    - allows arbitrary number of audio, video and subtitles streams in one file
    - attempting to support every existing audio and video codec under the sun
    - extensible by using EBML as underlying framework, a binary structure based on XML
    - enhanced container features such as menues, chapters, tags, file attachements
    - perfect sync thanks to timestamps for data blocks
    - x-platform design approach right from the start
    etc.
    Links :
    The release page ( constantly updated ) : !!!! http://www.matroska.org/announce.html !!!!
    matroska's homepage : http://www.matroska.org
    The project page : http://corecodec.org/projects/matroska
    CVS tree : https://corecodec.org/scm/?group_id=20
    Here a listing of the tools that are released today :
    LINUX :
    All existing tools, as well for matroska file creation as well as for playback, were made by Moritz 'mosu' Bunkus, the author of the well known 'Ogmtools' . He was implementing playback support into mplayer for Linux, and the matroska support code was commited to mplayer CVS a few hours ago. His file creation tools, and this includes the sources, can be found here : http://www.bunkus.org/videotools/mkvtoolnix/ . The program, in its current status, will allow you to transmux every AVI, OGM or matroska file into a new matroska file, plus to add several external audio streams from either WAV or Ogg sources ( Vorbis ) as well as AC3 and MP3 audio, and SRT subtitles.
    Currently Supported codecs :
    Video : all VfW/VCM codecs ( DivX, XviD, etc. ) ; Audio : Vorbis, MP2, MP3, AC3, PCM ; Subtitles : SRT
    WINDOWS :
    File creation : The VirtualdubMod Team around Julien 'Cyrius' Coloos and Tobias 'Belgabor' Minnich have implemented matroska reading, editing and writing support in such a professional way that Windows users will not have to suffer from any major drawbacks compared to the well established AVI format. The program is released from its usual place on http://sf.net/projects/virtualdubmod .
    Supported codecs are all : VfW/VCM codecs ( DivX, XviD, WMV9 VCM, ON2VP3, HuffYuf, H.264, 3ivx, MPEG4V3/2, etc. ) ; Audio : all ACM codecs , Vorbis, MP2, MP3, AC3, PCM
    Playback, DirectShow parser : Our core developer Jan 'myFUN' Schlenker created the basis, and the great development team from 'The Core Media Player' , mainly Ludovic 'BlackSun' Vialle and Christophe 'Toff' Paris, were pushing it to the actual release status. Please note that there is currently work done on the implementation of seeking as well as subtitle support ( to follow soon ). Occasionally the player may freeze if the pause/stop button is pressed. The file can be downloaded here : http://matroska.sourceforge.net/downloads/kaxdemux-v0.3.0.zip ; unzip it into any directory and run regsvr32 x:\path\kaxdemux.dll from a command line .
    Playback : The Core Media Player Team have made a special release of their feature pumped DirectShow player, the TCMP RC4 'matroska release edition' , to be downloaded here : http://www.corecoded.com . Its coming with the latest parser filter and will install it automatically, plus it can easily be registered to playback matroska files.
    MPA2MKA and WAV2MKA : Both programs allow the user to transmux PCM or MP2/3 audio file into matroska audio files and were developed by John 'spyder' Cannon and Jory 'jcsston' Stone . Link : http://matroska.sourceforge.net/downloads/mpa2mka.zip and http://matroska.sourceforge.net/downloads/wav2mka.zip .
    Future Features/Codecs ( still to come ):
    - Menues
    - Chapters
    - MPEG 1/2 video support
    - special mode 2 form 2 burning with ECC/EDC
    - Image Subtitles ( BMP and PNG )
    - Gstreamer plugin
    - Vegas video plugin
    - Xine playback patch
    - AAC audio support
    - Theora support
    - streaming server ( UDP and HTTP )
    - file attachements ( lyrics, cover images, etc. )
    - p2p plugins including file ID
    - Nero plugin
    - winamp plugin
    etc.
    We hope you will find the container useful and are looking forward to your feedback. Please adress all feedback either to the mailing list matroska-general at freelists dot org , join us on IRC.CORECODEC.COM #matroska or turn to the forum here : http://corecodec.com/modules.php?op…pBB2&file=index
    Thank you very much for your interest and my apologies to those who may feel bothered by the long postl
    Christian Wiesner
    Freut euch auf matroska, den neuen open standard für multimedia container Formate
  • Hehe...
    die "big pleasure" liegt ganz auf unserer Seite.:cool:
    Wenn die neuen Features, v.a. Seeking implementiert sind, spricht für Windows und Linux User einiges dafür, Backups (wenn nicht auf DVD) als .mkv anzulegen...
    Das einzige Problem, das ich sehe, ist die Unterstützung durch andere "große" Applikationen (Adobe, Ulead, etc.), die ja AVI immerhin mehr oder weniger unterstützen.
    Und bei standardisierten Formaten muss der Standard irgendwann "fest" stehen, d.h. man ändert keine Features mehr... so weit ist Matroska leider noch (lange?) nicht, oder?
    :seher: "Der Vorteil der Klugheit liegt darin, dass man sich dumm stellen kann. Das Gegenteil ist schon schwieriger." (Kurt Tucholsky)
  • Nun, bis wir alle features die möglich sind implementiert haben, wird noch ein wenig Zeit vergehen. Gott sei Dank haben wir aber bereits alles realisiert was sein muss in einem matroska file, d.h. die files haben bereits volle Gültigkeit und sind voll specs Kompatibel :) !
  • Steve 'robux4' Lhomme, unser Chefentwickler, hat ein iBook ... also denke ich mal daß das über kurz oder lang auf seiner 'to-do' Liste steht oder stehen wird ;) ....
    Originally posted by Selur MacOS-X ist ein Betriebssystem für Mac's :)
    .. und was denkst Du ist wohl ein iBook ?? ;) ...
    ...aber mir war klar das die meisten Leute iBook erstmal mit eBook verwechseln werden.
    Vor allem wenn die monoglotten Deutschen das "i" deutsch aussprechen, und das "e" englisch... :D
  • ach ihr nu wieder ..
    bevor das ganze wieder OT wird und ausartet
    @matroska ..
    bisher konnte ich nur den core media player bewegen mit das mkv abzuspielen .. aber is ja klar da die meisten damit nix anfangen können (das is keine kritik .. das is nur mal so gesagt :) )
    funzt schonmal ganz gut .. nur das mit dem seek müsst ihr unbedingt hinbekommen :D ich denke mal das is prioritätsstufe 1 - weil ohne is eben nich so dolle :D
    und wenn ihr mit den jungs von corecodet wieder labert .. sagt denen die sollen ihr videofenster "etwas" besser in den griff bekommen .. schaut schrecklich aus wenn ich das wärend des abspielens bewege .. scheint so als geniese dies nicht besonders viel process priority :D
    aber das ist nicht soo wichtig ..
  • Ich hatte vorher nur kurz Zeit ein bisschen damit rumzuspielen, aber das sieht doch recht gut schon aus.
    jetzt fehlt nur noch die breite Palette an Softwareunterstützung.
    P.S.: Wie weit ist eigentlich die "andere" MCF-Truppe? Wird da noch dran entwickelt?
  • Hab bissl getestet. Läuft ohne Probs im BS-Player und TCMP (kaxdemux-v0.3.1 installiert)
    Als erstes hab ich "nur" 'nen reinen Video-Stream genommen -> Keine Pronleme [Blockierte Grafik: http://forum.doom9.de/images/icons/icon14.gif
    Danach eine (VBR)MP3-Tonspur dazugemuxt. Ton von Anfang an und synchron -> [Blockierte Grafik: http://forum.doom9.de/images/icons/icon14.gif
    Hab nun noch eine 2 Audio-Spur in Form eines AC3 Streams mit dazugemuxt. Muxen ging einwandfrei, ABER BS-Player und TCMP spielen nur AC3 ab, also den zweiten Stream. Ein Wechsel ist nicht möglich! (Oder kann das Matroska noch gar nicht?) -> [Blockierte Grafik: http://forum.doom9.de/images/icons/icon13.gif]
    Oder muß ich ganz und gar noch etwas installieren? (Morgan Stream Switcher ist drauf)
    Cu Balm
    Edit: Ich dachte, ich bräuchte die Ankündigung vom 1.05. nicht mehr lesen, aber da stand es:
    Ob es hält was es verspricht ?
    nun, wir würden uns wünschen daß wir mit dem DirectShow parser filter schneller vorankommen würden als das jetzt der Fall ist. Das Filter spielt die Filme zwar, aber
    - ohne seeking
    - crasht manchmal
    - ohne subtitle
    - nur ein audio stream
    Originally posted by Kopernikus jetzt fehlt nur noch die breite Palette an Softwareunterstützung.
    Nic verspricht er wird matroska in DVD2AVI reinfriemeln .. mal sehen :D. Über VdubMod kommt matroska evtl. auch in GKNot. Wir sprechen mit den Leuten von Gstreamer, Xine, mencoder ( alles Linux ), sowie VLC ( http://videolan.org ). Igor will ein 'Vegas Video' plugin für matroska machen ( kenn das proggie leider gar net :D ). Nur ein winamp plugin für MKA files ( audio ) scheint wohl sehr hart zu realisieren zu sein, weil matroska eben so viele audio streams und codecs beinhalten kann.
    Darf ich zwar aus fairnessgründen eigentlich nicht kommentieren, sieht aber eher net so aus als wenn jemand wirklich dran wäre was zu programmieren. Aber die specs sind anscheinend mittlerweile auch komplett, und ganz gut geworden ... :cool:
  • Im Zoomplayer läuft bei mir auch soweit alles gut. Auch wenn ich den gleichen Fehler wie Balm mit 2 Audiospuren gemacht habe und dann "Doppelsound" gehört habe. Und ich dachte erst "Wieso hallt dass so?":lol:
    Noch eine Frage zu USF ist das ein text- oder ein bildbasiertes Subtitleformat?
    Viele Grüße bb empty
  • Hi Jungs,
    USF ist text basiert ( XML ) und kann ziemlich viel, karaoke, etc. http://usf.corecodec.org
    matroska wird folgende untertitel Formate unterstützen :
    Text :
    SRT ( ASCII )
    SRT ( UTF8 )
    SSA
    ASS
    USF
    Image :
    Sub ( BMP )
    Sub ( PNG )
    Ok ? :D
