Und die Version 0.54
Zitat von djobbsAlles anzeigenVersion 0.54
Below are a summary of the changes/updates associated with this version:
- Corrected error in which the "all contents of VIDEO_TS..." message was not suppressed when "Suppress Warning Prompts" was selected. Thx to jhmac.
- Changed output to .ECL files so "seq_endcode=1" is set for still frames this has been reported to fix problems associated with stills and BOV. Thanks to wmansir and Sir Didymus for researching, finding, and testing this fix.
- Corrected an error associated with CCE Basic that caused a "cce encoding failed: MPVA ... qsv 112 > 112" -- caused by an average bitrate that was calculated to an exceptionally low value.
- Fixed an error in which only the last two digits of the segment number were displaying in the status window. Thanks to jptheripper for catching this.
- Fixed error in which the the "Shutdown" options were not working correctly with Windows 2000 computers (stopped at the "SAFE TO REMOVE POWER" prompt). Thanks to archaeo for pointing out this error.
